Tranny temps. - Ford Powerstroke Diesel Forum
post #1 of 22 Old 09-11-2013, 01:06 PM Thread Starter
Tranny temps.
Hey guys, so I recently installed a brand new heavy hauler series fully loaded tranny from napc, and I'm seeing higher than normal temps while driving.. It is 90 degrees out but I am seeing 170-190 on my TFT .. If anyone has this tranny out there are these normal temps?
Sent from AutoGuide.com App
corycicuto is offline
post #2 of 22 Old 09-11-2013, 01:09 PM
portcity_gt's Avatar
Quoted: 1456 Post(s)
I like my trannys room temp.
As far as your transmission, those temps are higher than what my stock one runs.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 22 Old 09-11-2013, 10:20 PM
snafu!'s Avatar
Not 98.6?
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #4 of 22 Old 09-11-2013, 11:40 PM
JustinOOO9's Avatar
Quoted: 546 Post(s)
Garage
cruising 65mph on a 98+ degree weather flat ground im at 165-170 trans temp on my edge... yours could need a break in period? and you can always drop the pan, change both filters... i got my oem stuff cheap at dieselfiltersonline.com including mercon lv for under $6 a qrt thats right...
your temps sounds normal to me...
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #5 of 22 Old 09-12-2013, 05:33 AM
Originally Posted by snafu! View Post
Not 98.6?
Nope, too warm.
post #6 of 22 Old 09-14-2013, 03:20 AM
jimmyz32's Avatar
i have a very heave duty custom built trans. and mine stays around the 150* mark and it is hard to make it get hotter. I was told 150-180* is ok in a work load situation.
2004 F250 4x4
1) head studs
2) 4" turbo back exhaust MBRP muffler
3) super expensive built transmission
4) leveling kit and 3.73 gears with a locker
5) Full EGR delete
6) Air Dog 2 165
7) full set of gauges
8) ladder bars
9) smoke switch (I Don't use it)
10) eliminated banjo bolts for 90 degree fittings
11) tuned by lots of people
12) ported heads
13) 190/75%
14)Powermax turbo
jimmyz32 is offline
post #7 of 22 Old 09-14-2013, 06:00 AM
Gearhead2012's Avatar
Quoted: 3 Post(s)
Who does your tuning? I dont think it would have as much effect once your at speed, but some transmission builders recomend certain tuners for a reason. Is the converter locking? And is it a billet converter? Did you replace the trans cooler when you replaced the trans? And are you running the right fluid? Just thoughts that come to mind. If this was like your first run out with the trans maybe its normal to run hotter, i know it is during breakin for engines . We used to run engines on our dyno for ups, it was hard to keep em cool during the first major heat cycle. Not sure if transmissions follow suite.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #8 of 22 Old 09-14-2013, 06:55 AM
mechanix's Avatar
I would think the trans temp could also depend on the sending unit's location. I have mine right in the side of the trans and I usually see temps in the 150-180 range, upto 190 when pulling my camper in stop and go traffic.
Eric
03 F350 Super Duty
ARP head studs
Warren 155/30% injectors
Barder Stage 2 turbo
SCT Tuner
EGR delete
35x12.50x20 Nitto Trail Grapplers
mechanix is offline
post #9 of 22 Old 09-14-2013, 11:10 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Do you have a way to monitor the factory trans temp gauge digitally? If so, how close is your temps sensor vs. the factory one? I've always wondered this...
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #10 of 22 Old 09-14-2013, 11:15 PM
mechanix's Avatar
I'll hook up the Auto Enguinity on my laptop and go for a cruise. I'll post results within a day or so.
Eric
03 F350 Super Duty
ARP head studs
SCT Tuner
EGR delete
mechanix is offline
