stock turbo replacement wheel - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-10-2013, 05:55 PM Thread Starter
pa05stroker's Avatar
I wanna get a billet wheel for my stock turbo. my buddy just got the wicked wheel and I like how it made his truck spool faster and stuff. But I would like to try the MTW billet replacement wheel I was reading about it while searching for info on the wicked wheel. I got on MTW website and couldn't find anything about it. but to my question I would like to try and install this myself. how hard is it to take the turbo off and install one of these wheels. ive never messed with a turbo before. are there any special tools need for this, do they need balanced or anything. is there anything else I should get along with the wheel like gaskets or anything. does anybody know of a good video on youtube maybe that could help me do this? thanks in advance.
05 f250 crew cab short bed, 4" zone off road lift, 35x12.50xr17, eagle alloy wheels, young's farm service egr delete, ipr high flow coolant filter, 5" mbrp exhaust no kitty, SRL tune from gearhead, updated stc fitting, stand pipes, dummy plugs, and blue spring upgrade. and a lot of dreams.
pa05stroker is offline
post #2 of 8 Old 09-10-2013, 06:35 PM
5fifty's Avatar
The Wicked Wheel comes with the o rings for the drain tube. I would suggest getting the updated turbo feed line and drain tube it you are pulling the turbo. You need star sockets I believe it is 8mm and the large nut on the backside of the wheel is 7/8th standard socket . Take the bolts out of the center housing, put the large socket on the back side of the wheel. put a wrench on the nut on the wheel, remove (reverse threads) Remove stock wheel, install new wheel, and re assemble turbo. No need to balance. The shaft is already balanced.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #3 of 8 Old 09-11-2013, 05:49 AM Thread Starter
Thanks I already have the updated tubes. Do I need go drain the oil when I do this or is it not in the Turbo when the truck is off. And what exactly is the center housing. Sorry for the dumb questions. Just dont wanna screw up my Turbo.
post #4 of 8 Old 09-11-2013, 05:58 AM
kdogg85's Avatar
I believe he is talking about the compressor cover. You just unbolt the compressor cover, put the socket on the nut holding the compressor, socket on the turbine(you need to going the socket flat so it will grab, the turbine nut is very shallow and the tip end of a regulator socket will not grab it.)
Turn the compressor like you are tightening it to remove the nut(righty loosey, lefty tightey) in this case.
No you don't need to drain the oil, at least get a new gasket for the oil feed on top of the turbo. If the orings are not cut or nicked, they are fine. Get new orings if you see a nick.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #5 of 8 Old 09-11-2013, 06:24 AM
madpowerstroke's Avatar
The billet wheels never made it to the site yet, they go for 230.00 with shipping. Just call me and I will set you up on it. The wheels are very close to being the same so they should perform the same.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #6 of 8 Old 09-11-2013, 06:40 AM
c dog's Avatar
I dont know much about this but is there a benefit switching out wheels in a stock turbo?
c dog is offline
post #7 of 8 Old 09-11-2013, 07:04 AM
colonel angus's Avatar
Quoted: 2 Post(s)
Yep.....
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #8 of 8 Old 09-11-2013, 07:16 AM
King Rancher_27's Avatar
I just put the wheel from MTW in my powermax turbo. Same concept as yours. Really easy install!
Sent from AutoGuide.com App
-Casey
2012 F250 FX4 stock with 3.55 gears
2006 F250 King Ranch FX4--SOLD
ARP Studs-OEM gaskets(this time
SCT with IDP tunes,Gearhead tunes & TSD TUNES
EDGE CTS insight
5" TB with 6" Tip no kitty or muff
Sinister Delete Kit
Upgraded oil cooler
leveled w/ 295/70/18 Nitto Trail terrian
6.4 banjo bolts
Blue Spring Upgrade
KC Stage 3 68mm Turbo
Ported Intake
S&B CAI
190/75 Renagade injectors
STC fitting
King Rancher_27 is offline
