Wheels/Tires - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-10-2013, 04:11 PM Thread Starter
Wheels/Tires
I'm going to lift my 2006 6.0 with a rough country 4-4.5" lift. For my new wheels/tires... I was thinking 20" wheels, on 34"-35" tires....
I was going for a black and machined face wheel......I love the Helo 835, but they only come in a positive offset... [IMG]http://www.tirerack.com/wheels/MiniWheelSearchServlet?nonWinter=true&partNum=HE83529087318BMF&autoMake=Ford&autoModel=F350+Super+Cab+4wd&autoYear=2006&autoModClar=&wIndex=20&grid=true&sw=1440#
Having said that, what offset should I shoot for with that setup (4" lift, 20" on 35"s)? I was looking at -12? what do ya'll think
Tires.....any particular brand? I want them somewhat aggressive looking
Waylon6.0 is offline
post #2 of 5 Old 09-12-2013, 05:00 PM
colonel angus's Avatar
Quoted: 2 Post(s)
35's and 18's ride best, you need + Offset which is really tucked in, not out. This is why you can run factory 8" wheels or aftermarket 9" and a level kit with 35's you want +12 - +18 it will keep you from trimming the fender liners.
Check out Carli or DR ICON suspension systems they're pricey but carry a huge resale value and in anyone's opinion will out ride a Rancho Lift any day or night. If you're set on Ranch Oh! at a minimum change out the shocks to Bilsteins 5100's.
The best thing you could do would be to ride in a truck with the above suspensions before you make a costly mistake and have something you hate to drive or do twice.
Toyo AT's or the new Pricey Mickey T's Baja ATZ P3 are worth every penny if driven more on the highway or town than off road.
Any Mud Terrain tire is going to be louder and get less than mileage out of the set.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #3 of 5 Old 09-13-2013, 08:52 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 141 Post(s)
Feedback Score: 3 reviews
I run Weld wheels 20x 8.5 with a -6mm offset. That pushes the wheel out a tad when using 35"s.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #4 of 5 Old 09-13-2013, 05:35 PM
Rough country's 4.5" kit is designed to clear 35's with a 4.5" backspace.
I run their kit with a 35x12.50 on 20x9 with a 4.53 backspace
05 F350, 4x4, crewcab, 8' box, 4.5" lift, 35x12.5 general grabber extreme's rolling on 20's, SCT X3 loaded with Innovative tunes, Edge CTS, Pyro, Atlas 40, ARP Studs, Garrett PowerMax, MTW billet wheel, CFM+ LargeMouth, S&B, EGR & Cat delete, Full 4" turbo back, Aero turbine, billet water pump, Aluminum radiator, oil and coolant by-pass filtration, DC power engineering, Royalty core, Cervini's, N-fab, Bushwacker, Anzo, Diversi-tech, Nav, DVD, bluetooth, tunes.
05silverF350 is offline
post #5 of 5 Old 09-13-2013, 10:56 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Rough country is just that... ROUGH. Post some before and after pics.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
Tags
6.0 , offset , tires , wheels
