Installing a Turbo Back exhaust - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-10-2013, 04:42 AM Thread Starter
dieselforce's Avatar
I was wondering how hard it would be to install a turbo back exhaust? I have a MBRP turbo back the down pipe is 3.5 inch and a 4 inch back from there. I do have access to a Hoist and the ability to move the transmission cross member to have better access to the down pipe.
I am hoping to keep the stock exhaust in tact just in case I have to switch it back to stock in the future.
My ride is an 06 F250 Crew Cab short box thank you in advance
06 F250 XLT Crew Cab 4x4
6.0l Powerstroke Diesel
Suspension Maxx 2" lift/level kit
17x9 KMC XD Series Hoss rims
LT285/70R17 Toyo Open Country AT2 tires
SCT X3 programmer running Innovative Diesel Custom Tunes by Eric
MBRP Performance 4" turbo back muffler exhaust
Cat delete
Carpet Delete
Truxedo Bed Cover
dieselforce is offline
post #2 of 14 Old 09-10-2013, 04:49 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I went with the Diamond Eye 5" tb system and it was not hard at all....okay getting the first piece wiggled up to the turbo had me scratchin my head but that sucker did get up their.
Honestly this is a very easy diy job! The diamond eye system is awesome!!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 14 Old 09-10-2013, 04:51 AM Thread Starter
so would you say about 2 hrs or so?
My dad will be helping me do it and he has been an ASE master mechanic for over 30 years but diesels are new to him so that is our only concern
Cat delete
Carpet Delete
Truxedo Bed Cover
post #4 of 14 Old 09-10-2013, 04:55 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
oh I dont even know if it will take that long....I did it in a gravel driveway with a 12 year old in about a hour and a half.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 14 Old 09-10-2013, 04:58 AM Thread Starter
ok one last question do you have to remove anything from the engine compartment other than the turbo to down pipe clamp?
Cat delete
Carpet Delete
Truxedo Bed Cover
post #6 of 14 Old 09-10-2013, 05:01 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
No not that I remember. The best peice of advice I could give you is take your truck through a car wash that wash's the underside. And squirt some wd-40 on the rubber hangers. Your gonna reuse those and it will help.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 14 Old 09-10-2013, 05:02 AM Thread Starter
ok thank you for your help
Cat delete
Carpet Delete
Truxedo Bed Cover
post #8 of 14 Old 09-10-2013, 05:04 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
No sweat. Go with the 5"....you'll be glad you did! Good luck
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 14 Old 09-10-2013, 05:44 AM
Snake's Avatar
Quoted: 46 Post(s)
A write up I did a loooooong time ago
Anyone interested in an exhaust install thread? - TheDieselGarage.com
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #10 of 14 Old 09-10-2013, 06:03 AM
colonel angus's Avatar
Quoted: 2 Post(s)
I did the mbrp 4" w 3.5" down pipe too and it's a piece of cake, maybe took an hour or so... the wiggling the down pipe and turning it just right to get it out was the only hard part.
Also lay out the exhaust so you know which parts fit which pipes helps. and get the test pipe to lose the kitty, just lose it to the garage storage in case you ever need it later.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
