What kind of injectors?? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-07-2013, 04:50 AM Thread Starter
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Hello everyone. It's been a long while since I've been here. But I just need some advice. If you had to replace injectors would you go bigger or stay with a stock size? I still have to be able to tow a 26' boat. For those of you that don't know it's got the bullet proof egr with oil cooler and studded. Thanks for your opinion.
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #2 of 18 Old 09-07-2013, 05:47 AM
JGman141's Avatar
You could get 155/stock,175/stock, or 155/30 and still be able to tow with tuning.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 18 Old 09-07-2013, 05:50 AM
Slacker
Evil Eye's Avatar
Quoted: 224 Post(s)
Feedback Score: 4 reviews
When faced with that same decision, I sent with stock size injectors. I figured that with our heat in Arizona summertime, larger injectors would add too much heat load to the oil. I'm also towing 12k lbs... How heavy is your boat, Tyler? BTW, good to see you around.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 18 Old 09-07-2013, 05:55 AM
USAFBowman's Avatar
I went with 155/stock when I had to replace mine. My injectors were rebuilt by Warren Diesel and only cost me around $650 with overnight shipping.
I have heard 155/stock and a stage 1 MTW turbo are a great combo for towing. No experince myself but I plan to add a stage 1 to my truck after she gets studded
EDIT: 155s are approx like 30cc over stock, so not a huge jump but a little performance booster for sure
USAFBowman is offline
post #5 of 18 Old 09-07-2013, 06:34 AM
155/30 would be a good injector for a slight bump in power for towing. I always recommend warrens for injectors have had good experiences with them
2006 f250
on 37s
few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #6 of 18 Old 09-07-2013, 06:42 AM Thread Starter
scuffs *****
Tyler's Avatar
Hey evil, I wanna say its no more than 6, 500. It's only a tandem. Also looking at what would get me close to 500 hp at the crank. Sitting Around 430 ish right now.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #7 of 18 Old 09-07-2013, 06:46 AM
Slacker
Evil Eye's Avatar
Quoted: 224 Post(s)
Yeah, you should be fine with the 155's and adding a little larger turbo to improve your airflow. You *might* get to about 500, but doubtful. I'm also assuming you don't want to be towing at that power level. You'd need to bump up to 175's or even 190's, but then you'd really be adding some heat load if you towed at that power.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #8 of 18 Old 09-07-2013, 06:58 AM
U would need some good tuning to keep it cool and safe
2006 f250
on 37s
post #9 of 18 Old 09-07-2013, 07:08 AM Thread Starter
scuffs *****
Tyler's Avatar
I was thinking 190s maybe. Obviously it would need to be retuned. Trying to find a happy medium where it van tow with xtreme race like I do now and not have a meltdown, but its still scary to drive.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #10 of 18 Old 09-07-2013, 09:37 AM
mechanix's Avatar
I have Warren 155/30 injectors with a Barder stage 2 turbo. I tow my camper ( if i was to guess i am loaded at 8k lbs.) with a 80 HP tow tune from Eric at IDP, I see a max of 1250 egt's but mostly sit around 1050-1100 going down the road with the cruise set at 70. Very little smoke if any with the tow tune. I like it due to the fact I don't have to watch my egt's constantly.
Eric
03 F350 Super Duty
ARP head studs
Warren 155/30% injectors
Barder Stage 2 turbo
SCT Tuner
EGR delete
35x12.50x20 Nitto Trail Grapplers
mechanix is offline
