Do tuners use inferred EBP - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-06-2013, 05:49 PM Thread Starter
poorboy1964's Avatar
Quoted: 2 Post(s)
Not sure if I'm asking this correctly, have an 03 with a strategy of VXAP1**
I have assumed this is inferred ebp strategy but don't know. After loading my tune it was very smokey even with a light roll-in throttle. I contacted Vivian and she had concerns that there is a problem with the truck, I know it's very possibly but having a hard time finding anything.
I had her write a new one pulling fuel it is much better but not quite right. I started think while reading on here what if the Tune is not inferred EBP? it seams the same as stock but it's hard to compare number wise. I'll pull and clean the sensor and tube I just don't want to for nothing and risk trashing the tube.
Tom
2003 CCSB 4X4 6.0 Born on 5/03 Tuned by Vivian, 4" Turbo Back Exhaust, Edge CTS w/EGT, Coolant filter. ELC. fuel pressure gauge,
2002 SCLB 4X4 7.3 Stock
poorboy1964 is offline
post #2 of 10 Old 09-06-2013, 05:53 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
VXAP1 is inferred EBP. You said smoky on take off, did you for cracks/damage to the up-pipe/y-pipe bellows!
How about boost psi, if its lower than normal, check for CAC boots damage.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 10 Old 09-06-2013, 05:59 PM Thread Starter
Quoted: 2 Post(s)
Boost now I can hit 30psi and really haven't pushed it hard, with that nagging wonder if something is really wrong. With stock tune 26psi was the best I could get. I'll check for leaks tomorrow.
Tom
post #4 of 10 Old 09-07-2013, 05:41 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I doubt that you have much of a leak anywhere if you're seeing 30 psi of boost.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 10 Old 09-07-2013, 08:31 AM Thread Starter
Quoted: 2 Post(s)
That's been my thoughts too, It could be my truck is just a little different with the tune or there really could be something wrong that I cant find. this is why I was thinking about the EBP maybe not being inferred on the custom tune. I've gotta say this thing runs so good right now.
Tom
post #6 of 10 Old 09-07-2013, 09:57 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Do you still have egr pluged in?
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #7 of 10 Old 09-07-2013, 12:12 PM
peixinho's Avatar
Quoted: 217 Post(s)
How smokey is smokey?
What tune were you running before?
Are you rolling into the throttle or just mashing it?
Just the smoke clear up after a few seconds?
Could be normal if you are not used to using a hot tune
This might be a good read for you
I need a bigger turbo myths and how to drive a vgt turbo and turbo lag
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #8 of 10 Old 09-07-2013, 01:08 PM Thread Starter
Quoted: 2 Post(s)
Yeah Dale egr is plugged in.
No tune before started with Vivian's unlimited tune package on the Street tune and tow tune I can roll in slow and it helps. the first version of the looney was crazy I could blackout three lanes of traffic, she set me another one that was an injector tune she called and it's better, I can roll in to this one to help it.
I have read your link and I think all of your posts very good info you are sharing there.
Tom
post #9 of 10 Old 09-07-2013, 01:15 PM
peixinho's Avatar
Quoted: 217 Post(s)
3 lanes of traffic is definitely excessive! I really don't like super smokey tunes myself and am embarrassed whenever I do that... but it does happen. If you are building 30+ psi of boost, lots of power, have very little turbo lag, no weird egts... then it is probably just the tune
Looney was my first tune and I loved it for years... but I have found other tunes that I like for different reasons (not just because they are faster). I usually don't try to promote tuners too much because every tuner has their pluses and minuses ... but Matt at Gearhead prides himself in having tunes that are not super smokey and I can attest to him doing a good job of it.
KC Turbos
peixinho is offline
post #10 of 10 Old 09-07-2013, 01:28 PM Thread Starter
Quoted: 2 Post(s)
I understand there will be some smoke but yeah that was embarrassing. I switched back to the tow tune for now I'll watch it for a week and see. Might have to try something else just to see.
Tom
