EGR delete WILL set check engine light.
Just thought I'd let everyone that's been thinking of bypassing the EGR know that this will happen to them if running the stock tune. I normally run Innovative tunes, that turn off the EGR, and never have a light. But I've been driving my truck around for the last 3 days on the stock tune(been in and out of the dealer chasing a driveline vibration) and my light finally came on. So it took awhile, but the not-so-stupid computer finally found my "Sneaky" pipe. My Extreme Street file goes back in tonight.
Early 6.0's wont throw a CEL.
It is from Elite Diesel.
The one I seen was $165. Is that the one? Is it a pain to install and can I completely remove the EGR valve?
That's it. I put it on at the same time it was having head studs put on. So with the cab off, it was a piece of cake to install. |
My cooler is blocked off and when stock and the valve is functioning I do not get a cel, even for a cali truck. Oh and original egr valve, never been changed or cleaned.
I'll have to do mine with the cab on seeing as how I already have studs installed. I want to eliminate the EGR valve and throttle body completely so it is like the 05 and up trucks. I appreciate the info on the sneaky pipe. I was under the impression that it was around $500. I'll be ordering one soon.
My EGR is bypassed with freeze plug in the up pipe and EGR valve welded shut.
Yes, I also get the P0404 code. I have been clearing it and it reappears. I'm gonna try and run it and see if the cell goes out. I saw a post where one eventually went out
I know that no one seems to like Banks. That is why I no longer have the 6 Gun and am going to get an SCT. If I were you, I would ditch the Bully Dog and go with the SCT and custom tunes to shut the EGR off. |
