got big injectors. what turbo??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-02-2013, 06:57 PM Thread Starter
i have a 05 6.0 i just put the nonvgt arura 3000 turbo and i am thinking about get 225cc over 150% injectors is this a good set up or should i go back to the 68mm powermax?
bad6.0powerstroke is offline
post #2 of 7 Old 09-02-2013, 07:56 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I'd go compounds man no matter what single vgt you get your gonna run hot. Matt at cutting edge has a nice compound kit available and is affordable
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 7 Old 09-02-2013, 09:49 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
The 3000 is a relatively small turbo, I think you could run the 5000 with those injectors!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 7 Old 09-02-2013, 11:08 PM
madpowerstroke's Avatar
225/150 are way too big for street even with compouds. You will also have trouble maintaining oil rail pressure. 6.0 powerstroke don't like a lot of fuel anyway. You would have to give more info on what you have now and what you plan on doing.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #5 of 7 Old 09-03-2013, 06:20 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
150s are more nozzle than you need with 225s. The Aurora 3000 is a tiny turbo, I wanna say 58mm but I can't remember exactly. No one runs their stuff on the 6.0 anymore. Like was mentioned, you won't maintain ICP on a full fuel tune with 225s, so you would need to get dual HPOPs. A set of 225/100s is the biggest I would ever go with a single vgt. IF you went nonvgt single, like an S472 or bigger then you could go bigger on injectors, but be ready for some serious lag. You are better off going smaller on the injector, unless you are prepared to drop serious coin on other parts too.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #6 of 7 Old 09-03-2013, 07:14 PM
kdogg85's Avatar
100% nozzles max, hope you haven't made a purchase yet.
Anywho, you could run a 362 or 364 over 485 or 489. Or o lie MPD done and do a stock over 475 or 480.
If you have a welder and don't mind drilling your oil pan, you can do the job yourself, I would call cutting edge diesel for up pipes though.
There's a whole list of other things you should think about getting to go with it.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #7 of 7 Old 11-16-2013, 06:55 PM
sealeveloc's Avatar
Quoted: 19 Post(s)
I was about to start the same thread but about my 190/30's. I love my stage 2 Adrain but i gotta do something different. I did see 40psi out of it, but egts were ROLLING past 1600, flying by, and fuel psi dropped to 40 real quick.
Byron
O6 350 XL
The usual I wanna go fast mods,
maybe a lil more,
maybe a lil less
sealeveloc is offline
