sterling 10.50 gears - Ford Powerstroke Diesel Forum
post #1 of 21 Old 09-02-2013, 04:20 PM Thread Starter
585Amarillo's Avatar
I switched my 3.73 gears to 4.56 on the LSD and I'm trying to set up the pinion shims and carrier shims and the pinion is hitting the carrier case. I'M trying to find out what I'm doing wrong here any helps is welcome.
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #2 of 21 Old 09-02-2013, 04:39 PM
Do they use different carriers for lower gears?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #3 of 21 Old 09-02-2013, 04:48 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 111 Post(s)
Feedback Score: 7 reviews
might need a different carrier
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #4 of 21 Old 09-02-2013, 06:24 PM Thread Starter
There is no carrier break for ford gears.
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #5 of 21 Old 09-02-2013, 07:38 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Did you forget the crush washer?
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 21 Old 09-03-2013, 01:26 AM Thread Starter
nope I have it in there
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #7 of 21 Old 09-03-2013, 06:39 AM
william_ace's Avatar
Quoted: 2 Post(s)
Is it a new crush washer?
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #8 of 21 Old 09-03-2013, 06:40 AM
PGreenSVT's Avatar
Houston, we have a problem.
RIP Mitch
the Org crew
post #9 of 21 Old 09-03-2013, 11:00 AM
Gearhead2012's Avatar
Quoted: 3 Post(s)
What brand gears are they? That matters a lot. Some will tell you to start with the factory shims and adjust from there, but it all depends on what brand. If theyre Yukon gears, it'll take .016" additional pinion shims over stock, almost always. Sometimes .018. My guess is the shimming is just way way off.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #10 of 21 Old 09-03-2013, 11:52 AM
portcity_gt's Avatar
Quoted: 1464 Post(s)
On my truck 4:10 up takes a different carrier than 4:10 down.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
