Which turbo? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-02-2013, 04:49 AM Thread Starter
Which turbo?
Have an 07 6.0 in need of a turbo. Current set up is a Vivian's Looney tu e of stock gaskets and bolts. Not looking to push this setup any farther, so what should I use? Powemax, another stocker? I occasionally tow up to 12k (with stock tune in place), and would like to keep egt's down on the Looney. Best turbo and prices please.
lilbcollins is offline
post #2 of 3 Old 09-02-2013, 05:13 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Stock turbo with a billet wheel is your best bet IMO.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 3 Old 09-02-2013, 07:53 AM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
I agree with Nate .... You could also try the stg 1 MTW as it has a billet wheel in it when you buy it and it is a completely rebuilt turbo. You get a little extra performance for your money.
Todd
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
