Sinister Diesel Coolant Filter and Temp Sensor - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-31-2013, 09:27 PM Thread Starter
Mlivesay's Avatar
I have an 06 f250 6.0 and just placed an order for the Glowshift Max Tow EOT, ECT, and EGT. There are several threads for ECT sensor locations but very vague in regards to what im interested in. I want to install it in the extra port on my sinister coolant filter
Has anyone successfully installed a 1/8th NPT sensor inside the filter housing's extra port? Does it work well? Do you remember what size thread it is and where you got the adapter from?
Any help is greatly appreciated. I'm deployed right now and trying to round up all my parts for when I get home.
Thanks
2006 F-250 CC Long Bed - Leveled, Updated Oil Cooler, Sinister EGR Delete, 4" straight pipe, Blue Spring, PHP Atlas 40 FICM Tune, Sinister Coolant filter, SCT SF3, Glow Shift Max Tow EOT ECT and EGT gauges, B & W Turnover, 6 DVD changer with headrest monitors, Sound Off Signal Emergency FD Lights, Cobra 29 LTD/BT
Mlivesay is offline
post #2 of 6 Old 02-05-2014, 12:15 PM
llangarica's Avatar
Did you ever find out if the extra port on the coolant filter works for a sender location? i have the same one and am having the same concerns about it. thank you!
llangarica is offline
post #3 of 6 Old 02-05-2014, 08:03 PM
might not be enough flow thru filter to give good reading
padexcavate is offline
post #4 of 6 Old 04-23-2014, 08:13 PM
2004 powerstroke's Avatar
I put my sender there last week and temps are really low, I think I need to relocate to another. Temps read 165 ish.
:Canada:
2005 6.0 FX4 CC SB
SCT programer/ ARP studs/ sinister coolant filter/ FS2500 oil bypass filter/ Gauges:fuel-pyro-oil temp-coolant temp/ ficm upgrade/ blue spring mod/ high idle mod/ EGR delete
2004 powerstroke is offline
post #5 of 6 Old 04-23-2014, 09:39 PM
llangarica's Avatar
Is that after driving around for a while? What's the temp outside? Reason I ask is because I actually installed a digital gauge (scangauge 2 to be exact) and I see my ECT at about 185ish when it's 80 degrees out during the day and about 170ish when it's around 65 degrees at night. After about 30 mins of driving. So if it's pretty cool outside I think your temps are pretty close...
2005 Ford F250 FX4, Sinister Diesel goodies, ARP Headstuds, SCT Tuner, Innovative Diesel Extreme X Tune, Powermax Turbo, S&B Intake, Autometer Gauges, RCD 4-link 6" Lift, 33" Tires on 17" American Racing ATX wheels- SOLD [/url]
post #6 of 6 Old 04-25-2014, 06:51 AM
BigRedOne's Avatar
Quoted: 5 Post(s)
190 is the optimal temp and what the thermostat opens at.. my temps were 165 constantly before I changed the therm.. now its 190 no.matter the outside temp or driving conditions id double check that if your temps are that low. Sounds like it failed open.
2005 F350 XL 6.0
ARP studs
EGR delete
5" turbo back straight pipe
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
All upgraded OEM parts
BigRedOne is offline
