New Warren Trans- want to replace trans cooler - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-31-2013, 08:14 AM Thread Starter
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
I have a trans in route to me from warren and I am planning on pulling all hoses off and flushing everything. I am thinking I would like to replace my original trans cooler it has over 200k miles on it. The trans was not flushed or had fluid and filters changed in a long long long time. Its pretty much toast as well. I don't want a chance of getting any metal in the new one, so replacement is what I'm thinking. Im trying to put all my ducks in a row for the swap. What do you guys recommend? I talked with Andy about doing the 08 trans cooler and pan swap,(just briefly) how involved is that compared to just swapping with 6.0 OEM cooler? And if anyone wants to come play when it shows up just gimme a shout. lol And bring a trans jack! Thanks!
Byron
O6 350 XL
The usual I wanna go fast mods,
maybe a lil more,
maybe a lil less
sealeveloc is offline
post #2 of 12 Old 08-31-2013, 08:23 AM
ZMANN's Avatar
Quoted: 1789 Post(s)
you have 2 trans coolers FYI
and if your radiator has 200k also I would go for a performance radiator all aluminum since it comes with a new trans cooler inside .
the o9 pan is a great upgrade because of the real filter and I ran a Derale pan
I liked the 7 extra quarts and claimed extra cooling ( not endorsing the cooling claims or benefit of added fluid so no debates)
as far as the 08 air to fluid cooler it's not a common swap and since OEM is fine I would skip it but might be inclined to change it for new
We Miss you Ronnie
ZMANN is offline
post #3 of 12 Old 08-31-2013, 08:31 AM Thread Starter
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
OK so theres a difference in the 08-09 pans? Im looking for someone to hold my hand and walk me through this. Might take you out for dinner too
Cool, I will stick with the 6.0 cooler, but the pan sounds like it could be a possibility, maybe now maybe down the road. Do you have a link of removal for both coolers.
Oh and what radiator do you recommend, I get aluminum, but do you have a specific manufacturer? Is there a trans cooler in the radiator?
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #4 of 12 Old 08-31-2013, 04:22 PM
USAFBowman's Avatar
For aluminum radiator I would suggest BulletProofDiesel or Mishimoto. I have no experience from either but have looked into it and both are good quality, BPD is cheaper than Mishimoto.
USAFBowman is offline
post #5 of 12 Old 09-01-2013, 08:08 AM Thread Starter
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
Can some one explain the trans cooler, radiator relationship to me, is there actually a trans cooler in the radiator as well? Feel like a moron but I don't know how else to learn it without ripping it all apart. lol thanks
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #6 of 12 Old 09-01-2013, 08:58 AM
USAFBowman's Avatar
I'm fairly positive that there is a trans cooler inside the radiator as well such as most cars. This is your primary cooler for the trans, the separate one is a secondary for instances such as heavy load/towing and the trans goes above a certain temp. Someone correct me if I'm wrong but that's the way I understand it
post #7 of 12 Old 09-01-2013, 02:58 PM
Quoted: 58 Post(s)
These trucks have 2 trans coolers connected in series. The first cooler is located within the radiator and is a fluid-to-fluid heat exchanger. After the trans fluid leaves this first cooler it then goes to the air-to-fluid heat exchanger that is located between the intercooler and the condenser (and directly beneath the BPD air to oil cooler if you have one). The trans has a thermostat on the cooling lines such that below 165f the fluid stays in the pan and is not directed to the coolers.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #8 of 12 Old 09-01-2013, 03:10 PM
ZMANN's Avatar
the BPD radiator is just a Performance radiator brand radiator and it is stated correctly the trans cooler is captured in the bottom tank
I call the pan upgrade an 09 because 08 had 3 different styles of pans and filters
by 09 it was sorted
We Miss you Ronnie
ZMANN is offline
post #9 of 12 Old 09-01-2013, 03:10 PM Thread Starter
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
Thanks for the info. Rotated tires today and did a little snooping while I was under there.
I am gonna snag a BPD radiator I guess a stock replacement for the second cooler? Anyone have an other idea for that one and/or a part number
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #10 of 12 Old 09-01-2013, 03:14 PM
ZMANN's Avatar
just give sunrise ford a sponsor on here your vin and you will be guaranteed the proper part at a discount and free ship
then I suggest the Derale pan from Amazon or summit it will fit all years using adapters and grab the filter for a o9
from autozone just make sure it's a fram it will be the same as OEM
then save your existing pan gasket they are the best since they are reusable and have squish stops
We Miss you Ronnie
ZMANN is offline
