Sct tuner question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-31-2013, 04:42 AM Thread Starter
Sct tuner question
I'm in the market for a sct tuner and found a used x3 with 3 custom tunes from innovative, extreme street, street and tow brake.. This is off a 06 same as mine with those tunes work n my truck?
06banks is offline
post #2 of 7 Old 08-31-2013, 05:31 AM
mattmann86's Avatar
Not 100 percent sure, but I think you need to have the same strategies as the other truck?
mattmann86 is offline
post #3 of 7 Old 08-31-2013, 07:34 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 132 Post(s)
Feedback Score: 3 reviews
Check the strategy of the old truck and compare to your truck. You might get lucky, you might just want to play safe and get new tunes.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #4 of 7 Old 09-02-2013, 05:07 AM
Powerstroke Techie
Lilpooh's Avatar
What to look for when buying used SCT for 6.0
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 7 Old 09-02-2013, 05:16 AM Thread Starter
Yeah thanks for the replys, I've been reading about it and I guess the only thing I have to confirm now is the strategies, the unit is unlocked with 5 unlocks left and it's the older x3 pn 3000 with the ability to hold custom and canned tunes... So maybe I'll get lucky and the tunes will work but either way I wanted to add another tune so I'll probably just get this anyways... Is the only way to get the strategy off the sct or I can I read something off the computer.. I have no tuner or anything to look now unless there's a sticker somewhere that has it?
06banks is offline
post #6 of 7 Old 09-02-2013, 06:16 AM
Powerstroke Techie
Lilpooh's Avatar
Before you load the SCT to your truck, go to the SCT website and update the X3 to the newest firmware and tune revision. Don't go by the SCT part number (X3). To determine which X3 you have, go by the serial number. The older and newer X3 both use 3000 as the PN or model.
The only way to get the strategy is thru the OBDII port. There is no stickers or physical ID to determine the strategy. Of course SCT will read strategy, so will some scan tools like Autoenginuity and snap-on.
Lilpooh is offline
post #7 of 7 Old 09-02-2013, 09:07 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
You can read the strategy your trucks ecm has before you load the tune in the truck. But I'm not sure how to tell what strategy the tunes are programmed for.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
