Gearhead SRL tune- first time use - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-30-2013, 06:53 AM Thread Starter
Soledad's Avatar
Garage
So.....I installed my first ever "custom tune" on this truck yesterday. I hadn't even been running the canned SCT tunes. I just went straight to a custom tune.
Anyway, here's what I've done to the truck (it ain't much):
1. 4" turbo back exhaust with muffler and 4" down pipe
2. PHP Atlas-40 FICM tune
3. blue spring mod
4. ScanGauge-2 and 3-in-1 Glowshift gauge
5. Coolant filter
Intake, EGR, head bolts are all still stock.
I went to Matt @ Gearhead and got his package of 3 tunes (SRL, 8kTow and Unlimited Tow). I ordered them Wednesday and got them Thursday. Now that's service!
I wanted the full monty so I went right with the SRL tune and installed that during my lunch hour. I started the truck up but found that my ScanGauge-2 wasn't reading any of the extended PID's now. I didn't have much time to troubleshoot so I turned the truck off. After work, I started the truck up and again noticed the ScanGauge wasn't working right. I unplugged it and plugged it back in but no joy. I turned the truck off and restarted it and again no joy with the ScanGauge. With no time to troubleshoot I headed to the grocery store. When I came back out and started the truck up the ScanGauge was now reading correctly. I have NOOOOO idea why it did what it did after I installed the Tune but I have read of one or two other people that had the same issue.
Anyway, while pulling out of Safeway I decided to check out the tail pipe smoke and got on it just a little bit. There was no smoke. I thought "hmmmm....I'll just get on it hard and then see how much it smokes". Well, it scared the **** out of me because I was not expecting it to take off like a bat out of hell. And when someone said that it changes the sound of the truck, oh hell yeah it does. That thing got mean and nasty sounding like it was eating up small children for lunch. I looked up and saw my EGT's climbing really fast so I let off at 55mph and checked the rear view mirror. There was some dark brown smoke but nothing like rolling coal. I was now extremely impressed.
Here's what I noticed on my 22 mile drive back from the grocery store:
- It's now waaaaaaaaay faster than with just a 4" turbo back exhaust and FICM tune.
- The truck is more responsive on take off and just driving around town.
- The EGT's climb really fast so I'll have to be keeping an eye on them when I get on it hard.
- During normal easy driving and highway cruising the EGT's are actually lower. I expected them to be higher. The same mile-long hill just before the exit to my town, I would hit 780-800* with the FICM tune and 4" exhaust. Now it's hitting 700-720*. I'm not quite sure why that is especially if I'm running the hotter tune.
- During normal driving the truck sounds the same. Get on it hard and holy moly it snarls.
- I may look look into a water injection system just to help with the EGT's.
And, from here on out I gotta be careful and start planning for the inevitable headstud/headgasket repairs.
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
post #2 of 12 Old 08-30-2013, 08:12 AM
HP MACHINE's Avatar
Quoted: 152 Post(s)
Probably something to do with KAM , my scanguage and my Edge cts both have to
reset after loading any tune .
SRL+ here and love it . I run mine with PHP econ and srl+ combined and have virtually no
smoke and good fuel mileage . The driveability and shifting are the best I have found yet
for street daily driving with My truck
HP MACHINE is offline
post #3 of 12 Old 08-30-2013, 08:30 AM Thread Starter
Soledad's Avatar
Garage
By the way, is there a way to adjust the Tire Revs Per Mile without having to reload the Tune again? (I have an SCT SF3) I set my Rev's to a value I calc'd using an online calculator and the speedo is still off. Tonight I'm going to actually measure and then readjust the Revs Per Mile in the SCT again but I wasn't sure if there was a way to do it without reloading the Tune.
Thanks!
Soledad is offline
post #4 of 12 Old 08-30-2013, 10:05 AM
HP MACHINE's Avatar
Quoted: 152 Post(s)
The SCT asks you before you load the tune if you would like to change any options
( i.e. tire size , revs per mile etc. ) . There is a whole list available when it appears .
post #5 of 12 Old 09-02-2013, 09:03 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Only way to change the revs-per-mile is to change the settings and reload the tune.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 12 Old 09-02-2013, 09:38 PM
ZMANN's Avatar
Quoted: 1674 Post(s)
changing settings like revs or shifts ETC is a lot faster than actually loading a tune from stock
tunes have never upset My Edge CTS
We Miss you Ronnie
ZMANN is offline
post #7 of 12 Old 09-03-2013, 06:48 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Thanks!
Setting revs/mile only effects the trans shifting points it does not correct for speedo errors.
RIP Mitch
the Org crew
PGreenSVT is offline
post #8 of 12 Old 09-04-2013, 09:19 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 132 Post(s)
The newer SCT firmware allows users to adjust the speedo. I'm running 35"s within 1MPH of GPS and roadside radar units. I typically see less than 1% difference in my Trip odometer and GPS trip odometer.
For my SF3 I will see the menu option as I go thru the sequence to load a tune. This "tire rev" option is usually done prior to the sequence that starts loading the tune file.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #9 of 12 Old 09-04-2013, 09:24 AM
N.S.D.Q.
Quoted: 132 Post(s)
Thanks!
You got to have the tire rev measured out first. Make a mark at the 6 o'clock on the tire and extend it to the ground. Allow the truck to roll the tire one complete revolution, mark the ground a second time. Measure the distance in inches. Divide 63360 inches (inches in a mile) by the inches between the two marks. You may find the revs to be closer yet still off. Adjust the tire rev setting 1-2 up/down till it's spot on.
I have done this between the last two sets of tires and always get the speedo within 1 MPH of GPS/ roadside radar units.
post #10 of 12 Old 09-04-2013, 10:02 AM Thread Starter
Soledad's Avatar
Garage
Thanks HA. That's exactly what I did a few days ago. I measured the tire and then did my own calc and came up with 657 which is just one higher than what Hankook posts for their Dynapro ATM at a LT265/70R17. This put me within 1mph of my GPS's and I'm definitely happy with that.
And thanks for the validation that the tire revs change occurs just before "the sequence that starts loading the tune file". I was thinking maybe I missed something somewhere and you could adjust the tire revs without having to go through the whole tune process but alas I guess you can't (which really isn't a big deal anyway).
Now if I could just figure out why it shifts into OD so damned early at light throttle. I don't know if that's a function of the custom tune or yet another changeable parameter in the SCT SF3.
Soledad is offline
