who sells 03 wheel? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-29-2013, 11:48 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
who sells 03 wheel?
I'm looking at putting a billet wheel for an early 04. I can only find a dual plane wheel I want a single plane wheel. Any help appretiated.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #2 of 15 Old 08-30-2013, 12:17 AM
turbotibbo's Avatar
Check out mad turbo works or dieselsite
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #3 of 15 Old 08-30-2013, 12:47 AM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
Ill check again but thought they only had the dual plane.
04 f250 cc sb.
jmeaby is offline
post #4 of 15 Old 08-30-2013, 01:06 AM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
so I only found on diesel site the dual plane wheel. does anyone made a single plane wheel for the 03 turbo? hoping someone from mtw will join in
04 f250 cc sb.
jmeaby is offline
post #5 of 15 Old 08-30-2013, 02:51 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Single is in production from Diesel Site. It will be coming soon.
MrOneEyedBoh is offline
post #6 of 15 Old 08-30-2013, 03:08 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Our 03-04 wheels are single plane now. They use to be dual plane (03-04 wheels that is. 05-07 wheels were always single plane). Let me know if you'd like one.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #7 of 15 Old 08-30-2013, 04:36 AM
Jennifer@Dieselsite's Avatar
Quoted: 4 Post(s)
I don't think this is correct... I can double check with Bob but I just got a lesson in turbos and wheels from him yesterday and making a single plane for these turbos wouldn't make sense (to me! lol)
I'm quite sure the one we have now for the 03-04's is the one we'll be keeping, but again I'll double check.
Last edited by Jennifer@Dieselsite; 08-30-2013 at 05:09 AM. Reason: EDIT - Added "to me" because I'm still learning and whatnot.
Jennifer@Dieselsite is offline
post #8 of 15 Old 08-30-2013, 04:56 AM
BACKYARDIGAN
Quoted: 4 Post(s)
Originally Posted by Jennifer@Dieselsite View Post
I don't think this is correct... I can double check with Bob but I just got a lesson in turbos and wheels from him yesterday and making a single plane for these turbos wouldn't make sense.
Good to know.
I know with the testing we've done, we're not going back to the dual plane design for these turbos.
Nate
post #9 of 15 Old 08-30-2013, 07:34 AM
bondajb's Avatar
The year of the truck is not a sure way to size your compressor wheel. My 05 had a 59mm reman turbo.
My stock wheel was damaged by some shapnel left from a previous turbo failure. So I had to get a new wheel. I gave one of my contacts a shout and was sent two wheels... a 7x7 and a 11b. I installed the 7x7 first. Ran it for 2 week..if which is not a lot of driving for me. I even did a Tow with it.
with out changing anything but swapping to the 11 blade. I noticed an increase in idle maf readings. So egt came down quicker. Off the line respone was up and take off smoke was down. Criuising egt were down and milage was up all with the 11 blade. I also notice turbo fart was significantly less with the 11b.
I never got a chance to comparing in a tow cenerio but I am confident the 11b would have been my choice. Unloaded on the top end I did not notice any difference. The lower rpms..2400 and under the 11b had a bigger improvement on my truck and that is the wheel I purchased.
note that all improvements were subtle but were there!!!
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #10 of 15 Old 08-30-2013, 12:40 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
It's my understanding normally dual plane is better for higher rpm engines then for lower rpm like these I don't know. Nate when did u guys start selling the single plane version of your wheel for 03_04 trucks and how much and are they in stock?
04 f250 cc sb.
jmeaby is offline
