rookie question....what's next? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-29-2013, 06:13 AM Thread Starter
cmagee's Avatar
bought the truck with everything in my my sig already on it. i want it to be a daily driver that i can sled with and be competitive. i realize the obvious, like a tuner and dual disk, i just wanna make sure i'm not forgetting anything. sorry if this has been gone over before, but as far as i can tell, the truck is already built. just wanna make sure nothing was overlooked. thanks for any input
Colten
03 RCLB 4x4 6spd 6.0, GT3788VA, AFE stg 2, deletes, oil cooler, p/p heads/valve guides, ported intake manifold, updated springs, oil o rings and fittings, 58v FICM with mild flash, blue spring upgrade, 6.4 banjo bolts, 155/75 injectors, FASS lp, 3"dp to 5" exhaust, studs, autometer boost, pyro, fuel, 550hp clutch, 8" lift, 37x15 toyo mt's, 485hp/912tq on stock tuning
cmagee is offline
post #2 of 11 Old 08-29-2013, 12:25 PM
Looks like a solid setup to me. Only thing I didn't see was a coolant filter. Not a performance mod, but a great addition to help the longevity of your engine. With everything listed it should run pretty good. Next step maybe some larger sticks and air to match.
2003 F-250 ECSB 4x4
4" MBRP turbo back
SCT
S&B cai
435 rwhp / 767 rwtq
13.94 @ 97 (with a terrible 60')
Jesse S is offline
post #3 of 11 Old 08-29-2013, 12:29 PM
Wow, just re-read everything. Yes you definately need custom tunes, but 485/912 on stock tuning?!
2003 F-250 ECSB 4x4
4" MBRP turbo back
SCT
S&B cai
435 rwhp / 767 rwtq
Jesse S is offline
post #4 of 11 Old 08-29-2013, 12:44 PM
You forgot one thing and the big one --> Plenty of money for when things break. Sounds like you have a pretty solid truck from all the mods you listed. Good luck in your pulling endeavors.
Oh, one more item you may need is a beater incase you can't fix your truck really fast.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #5 of 11 Old 08-29-2013, 12:51 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
LOL!!!!^^^^^^^
How about a digital monitor to along with a SCT tuner.
Write Up: Monitoring the 6.0L PSD.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 11 Old 08-29-2013, 04:29 PM
snopro_03's Avatar
If your really wanting to be competitive sled pulling lose the lift and tires. Also traction bars and a rear locker would be a healthy addition.
Chad
2003 6leaker
N.E.W 2.5 Truck
snopro_03 is offline
post #7 of 11 Old 08-30-2013, 03:31 AM Thread Starter
cmagee's Avatar
thanks for all the input guys. the money part isn't so much an issue right now because i'm still in afghan so i got a little bit saved up. as far as the beater goes, i'll have to find a metro or something lol. and the coolant filter is ordered. sorry for another rookie question, but i'm coming over from the cummins 24v world, so i've never had to deal with custom tunes. how does all of that work?
Colten
cmagee is offline
post #8 of 11 Old 08-30-2013, 04:15 AM
JustinOOO9's Avatar
Quoted: 419 Post(s)
Garage
welcome to the org and thanks for your service!
for custom tunes you'll need an sct tuner or a converted edge, typically a sct sf3 or sct x3. next you plug in tune and get your vehicles strategy code, and vin and give that to custom tuners along with all mods, and what your looking for. most time you get an email and just load the tune to your tuner through you computer with a usb cord. ill find the thread about custom tunes and where to get but...
gearhead automotive i believe panty dropper and super panty droper tunes.
eric @ innovative diesel
vivian @ quicktricks
tony wildman tunes (can't remember the shops name)
there are a few more well known custom 6.0 tuners everything from shift points, when overdrive kicks in to when you want your engines an to turn on earlier or later etc...
dont build a sled puller/ daily driver kinda a hard mix to maintain... find a beat down 6.0 and throw some money in it and make that the puller. a lifted truck can do it but lower will be easier on the truck and will lesson the track bar necessity at the get-go.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes,
currently-1999 F250 SBRB 4X4 First 7.3, 6.0 trans cooler made my muffler fall off
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #9 of 11 Old 08-30-2013, 06:21 AM Thread Starter
cmagee's Avatar
alright. i plan on going lower in the future, i just gotta check and see if the drive shafts were lengthened or not and i don't think my tires will still clear at full lock or if i'm pulling in a driveway or something. i'll prolly wait till they are worn and have to pick up new ones. and you mentioned shift points and when o/d kicks in, i'm wondering how that will work since i have the zf6? sorry for all the questions, i'm just trying to do this right the first time. wasted way too much money on my last diesel from just throwing parts at it trying to make it fast
Colten
cmagee is offline
post #10 of 11 Old 08-30-2013, 01:27 PM
305f250's Avatar
Front Driveline is probably lengthened, you can take it off and drive no problem until its shortened. The rear stays the same
305f250 is offline
