How to check if EDGE fuel pressure sensor is bad? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-26-2013, 11:17 AM Thread Starter
5fifty's Avatar
Noticed today that my fuel pressure was reading 100psi at idle. When I shut the truck off it stays at 40. How do I check to see if the sensor is bad?
TIA
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #2 of 9 Old 11-19-2013, 04:45 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
TIA
what did you figure out?
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #3 of 9 Old 11-19-2013, 04:56 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
When I shut the truck off it stays at 40 psi.
I think he realized he answered his own question.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 9 Old 11-19-2013, 11:28 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
sounds bad to me, ive had 2 sensors do the same thing to me now. both were bad
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #5 of 9 Old 11-20-2013, 05:48 PM
Mine was doing the same thing a while ago....just under a year on the warranty, Edge sent me a new one free. I just had to send the bad one back.
nghtrgr is offline
post #6 of 9 Old 11-22-2013, 03:15 PM Thread Starter
5fifty's Avatar
I got it all squared away. Bought a fuel pressure test kit from harbor freight. Checked pressure from test port. Was getting 61psi at idle. It was a bad sensor. Called Edge and they sent me a new one under warranty.
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #7 of 9 Old 11-23-2013, 04:57 AM
HP MACHINE's Avatar
Quoted: 151 Post(s)
If they keep going bad , change brands ( make sure you get a calibration chart ) and
customize your unit with mystyle . just about any 0-5 volt sensor will work , you just
have to re wire the respective connector on to your harness .
HP MACHINE is offline
post #8 of 9 Old 11-26-2013, 05:15 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Edge is sending me a new one. Don't know how they can tell if it's bad or not.
WarChild is offline
post #9 of 9 Old 11-29-2013, 07:01 AM
1fastTRX's Avatar
ISSPRO has a good troubleshooting chart if anybody wants to troubleshoot it on their own. I had an issue with my gauge... it turned out to be the gauge and not sensor. Obviously doesn't apply to Edge completely, but it can help. Just need to know how to use a multimeter.
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
