6.0 pushrods - Ford Powerstroke Diesel Forum
post #1 of 41 Old 08-26-2013, 05:23 AM Thread Starter
Chatham036's Avatar
Quoted: 136 Post(s)
6.0 pushrods
Alright ladies and gents... This thread is to distribute some insight to you all as well as ask for your feedback on my thought process.
So theoretically when you get your head resurfaced, they typically pull off several thousands..
This effectively over extends your pushrods by the same length. This can cause the valves to remain open/ not fully seat and cause bent pushrods(I think), or even break rockers
NOW to my question to you all...
The 6.0 pushrods are exactly 9.847
The 6.4 pushrods are exactly 9.800
Should we be installing the 6.4 pushrods upon rebuild to eliminate this issue?
Furthermore, ford has since quit making the 6.0 pushrods. If you bend yours and need replacements, they issue you 6.4 rods.
To recap, upon rebuild of my motor, I suspect it would be intelligent to run 6.4 rods rather than reusing the 6.0 rods.
Thoughts?
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #2 of 41 Old 08-26-2013, 05:36 AM
Macon's Avatar
It wouldn't hurt. I think "need" depends more on how much was taken off your heads. I'm sure you can ask of 0.047 to be taken off so you have a factory match.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 41 Old 08-26-2013, 05:43 AM
jmsmith76's Avatar
In theory, it would make sense to me to run the 6.4 rods
jmsmith76 is offline
post #4 of 41 Old 08-26-2013, 05:51 AM
powerstrokecrzy's Avatar
Quoted: 250 Post(s)
I had .06 taken off one head. .10 taken off the other with valves ground down to ensure clearance. Re installed push rods that were in the truck. That was a year ago with zero issues up to this point. And I've made plenty of hard runs with it and pulled some heavy loads.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #5 of 41 Old 08-26-2013, 06:30 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
How much of the difference would be accounted for by the hydraulic lifters.?
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #6 of 41 Old 08-26-2013, 06:37 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Originally Posted by Chatham036 View Post
...The 6.0 pushrods are exactly 9.847
The 6.4 pushrods are exactly 9.800...
I know my heads only had about .004" removed when they were done so that puts me at a 9.843" pushrod. I would rather let the hydraulic lifters take up the excess valve lash that shortening my pushrods by .043" and making my hydraulic lifters pump up more to get enough lash to fully open my valves.
Just my thought.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #7 of 41 Old 08-26-2013, 06:49 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Just my thought.
Exactly my thought as well. I don't see taking .006 off the heads needing a .047 shorter pushrod. The hydraulic lifter should take care of that without any problem. I also can't see this being a cause of bent pushrods. If you have to take more than .008 off then the valve seat needs to be recessed and the appropriate amount removed from the valve stem. This maintains the installed height of the valve and the geometry of the valvetrain. No need for shorter pushrods.
RIP Mitch
the Org crew
PGreenSVT is offline
post #8 of 41 Old 08-26-2013, 06:53 AM
sargar's Avatar
Good question Jay. Have you asked this question to Machine Services? I don't think that you can take enough off of a 6.0 head to make up the difference in push rod length but with a hydraulic lifter, I also don't think that .047" is anything to worry about. The valve will fully close and seal, what you would have is less valve opening. What is the rocker arm ratio on a 6.0? By the time you do the math between the two rods, I think your difference in valve opening will be less than .047". I hate to go the lazy route on an expensive engine but.....if a 6.4 pushrod is all you can get as replacement, then it must work. That being said, I think I would want all the same length push rods. Then there is the custom route.......
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #9 of 41 Old 08-26-2013, 07:16 AM Thread Starter
Chatham036's Avatar
Quoted: 136 Post(s)
I am not as familiar with hydraulic lifters as I should be so I am learning as you all talk about their function.
I spoke with Jim Hansen at my machine shop (Engine Services) and he mentioned they will swap the rods out on each 6.0 teardown. He recommended that I go that route.
The set of 6.4 pushrods are $65 from ford. Akins ford also confirmed the part number matched the 6.4 rods
post #10 of 41 Old 08-26-2013, 07:48 AM
BACKYARDIGAN
Quoted: 4 Post(s)
FWIW, RCD only sells 6.4/6.0 pushrods that are 9.850" long (as per Jared). My 3/8" smith brothers pushrods are that length as well.
Nate
The Following User Says Thank You to windrunner408 For This Useful Post:
Mystic Cobra (09-21-2014)
