EGR delete w/tune? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-25-2013, 07:30 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
EGR delete w/tune?
Can you do a EGR delete with a tune that will just shut off the valve so your not dumping trash down the intake?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 8 Old 08-25-2013, 08:04 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
Many custom tunes shut the egr valve off. High back pressure can forge it open still. I've been told the valve should stay intact as it controls the fan clutch while towing.
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #3 of 8 Old 08-25-2013, 09:42 PM
USAFBowman's Avatar
Yes you can turn it off. But at the same time you still have coolant and exhaust flowing through the cooler so the cooler can still possibly fail on you.
USAFBowman is offline
post #4 of 8 Old 08-26-2013, 08:49 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
You will only have exhaust flowing through the cooler if the valve is forced open as Teachamech states above. If the valve is closed it is blocking off the engine side of the egr system. But yes you still have hot gas in the egr cooler and it can still fail on you. It is best to delete it if you can. If you can't a BPD cooler and turning it off in the tune is the next best thing.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 8 Old 08-27-2013, 09:47 AM
Quoted: 398 Post(s)
Garage
My next step would be to either weld up the cooler on the up pipe side(both would be better) or use a block off plate(there's some discussion on this in other threads). The really important thing is to remove the scoop in the up pipe(05-07) so the exhaust gasses can flow freely to the turbo.
I live in CA so we have emissions testing... So I have to appear as though the egr system is intact. :what:
post #6 of 8 Old 08-27-2013, 02:06 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Well I found on my SCT were I could do just what I asked so I did indeed turn it off. I will go ahead and to the total delete next time Im in their but for now its all good. I dont have any thoughts that the cooler will fail being its basicly new and Bullet Proof.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 8 Old 08-27-2013, 07:43 PM
Quoted: 398 Post(s)
Garage
Originally Posted by kinnisoj View Post
sI dont have any thoughts that the cooler will fail being its basicly new and Bullet Proof.
Sounds like you're good to go!
post #8 of 8 Old 08-27-2013, 08:11 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I gotta say I learn something everyday on here!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
