Possibly turbo up pipe leak? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-25-2013, 03:49 PM Thread Starter
TNFireman's Avatar
Sooo I put my new turbo on for my 175's and I have high egt's and can't build more then 18lbs of boost.
I have new tunes from Eric written for my combo. I can push 1200 on a moderate hill barely on the throttle.
It seems the old turbo ran better and made more boost.
Sooo I've been looking but can't see any soot on the firewall.
Should I pull the clamp and loosen the manifold bolts for te up pipes and try again?
Or is that just nature of the beast?
I cannot even pull my trailer right now. Good thig I have the 7.3 as a back up..
I'm gonna give Ted a call tmrw and fix my x tune and ask him what's going on.
If its my fault with not lining it up right ill fix that tonight.
It's not that hard to do .
94 F350 xlt, 4x4, 7.3 idi turbo cc/lb 36" maxis buck shots getting paint!!!
06 F2504x4 PSD KR, H11studs,175/75's from warren ordered!!,idp tuned ficm egr delete IDP Custom tunes mbrp 5" edge Insight cts with pyro and isspro fuel pressure gauge, air dog 165 to put on and turbo to order RCD 68mm or powermax modded
IAFF Member International Association of Fire Fighters
TNFireman is offline
post #2 of 8 Old 08-25-2013, 03:56 PM
colonel angus's Avatar
Quoted: 2 Post(s)
Absolute up pipe leak.
Best to loosen the up pipe manifold bolts and make 100% sure the flange fits inside and tight to the turbo.
To check for a leak let it get dark and with a high powered flashlight climb above the engine and shine on the turbo, then from below on both sides of the engine, exhaust smoke shows up great in light.
Once you have it on correctly, you'll know instantly.
The Turbo to up pipe v-clamp DOESN'T pull the pipes flanges together.
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #3 of 8 Old 08-25-2013, 04:08 PM Thread Starter
TNFireman's Avatar
Good deal ill do that tonight once the truck cools off. I did not loosen the up pipes from the manifolds when I installed it. Last time I swapped a turbo it was at a shop for studs and had them do it.
If I get it right ill hitch it to my trailer tonight for tmrw I'm gonna drag the gooseneck to work to piddle on making a toolbox to mount on the top deck.
I'm surprise I can't hear it.
That's my fault rushing it
post #4 of 8 Old 08-25-2013, 04:29 PM Thread Starter
TNFireman's Avatar
It's a smokey dude too
post #5 of 8 Old 08-25-2013, 05:51 PM
Quoted: 2 Post(s)
Knot 4 Long!
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #6 of 8 Old 08-25-2013, 07:18 PM Thread Starter
TNFireman's Avatar
Well I took 30 min under and over the truck wearing fire fighting gloves so I didn't get burned.
But I was able to pop the clamp loose and see a gap. Loosene the bolts at the manifold and lined everything up. Tightened it back down an my egt's dropped 300 degrees haha cruising now at 2-4 lbs of boost I'm high 500's-750 depending on grade empty.
I did hook up my trailer and it's about 4500-5000 empty an went for a spin. Saw 28lbs of boost and 1250 pulling a steep hill at 65mph. Pulls in tow tune lil it moved itself in a race tune on stock injectors. Very impressed actually gonna have my tow tune backed down a lil bit to keep the egt's a little more in check. If that doesn't help ill do a gogo intake manifold and water injection.
Need to get my new fan clutch on. ECT is around 198 flat ground towing empty and goes up to 210 or so climbing hills. Freaks me out towing an empty trailer. Maybe my radiator needs to be cleaned too.
post #7 of 8 Old 08-25-2013, 07:44 PM
Quoted: 2 Post(s)
It's also a matter or learning both with the tranny and the engine so give it a few days it will come around.
Glad to hear you're a Turbo Pro now.....
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
VXCF9CA TQCI1NB
post #8 of 8 Old 08-26-2013, 08:57 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Doug Gilbert aka Gogo Diesel is a thief and a liar and generally a human fail. He stole my Intake and never did any work on it lied to me every time I talked with him. After 6 mos I had to buy another intake and port it myself. Do business with him at your own risk. There's a good reason so many vendors have quit dealing with him and a number are suing him.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
