66 MadMax - Ford Powerstroke Diesel Forum
post #1 of 31 Old 08-24-2013, 11:31 AM Thread Starter
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
66 MadMax
Well as many of you know, Adrian sent me a 66 MadMax to do some initial testing so we could hopefully see whether or not this turbo would be worth going further with the development to see if it could possibly be used with medium sized injectors.
As of right now, this is just an "initial impressions" sort of thread. I've only been able to get about 30 miles on the turbo so far, and the local traffic situation didn't support doing anything crazy today, but I can say without any doubt that this thing is definitely flowing more air and making more power than either the Hybrid or Stage 1 turbos do. It's been a long time since I've had a Stage 3 on my truck but the way this thing drives reminds me very much of what I remember the Stage 3 being like.
Based off of MAF readings (boost for boost) on my CTS, this turbo is flowing an easy 20% more air than I was seeing with the Stage 1, which felt stronger on my truck than the Hybrid did. This turbo does spool ever so slightly slower than the Stage 1 did (on a stock turbo tune), but it isn't anything to get shook up over. I currently don't have any special tunes written for this turbo yet so I don't think it is a good idea to really talk about the spool up. I do know that I require about 2-3% less pedal to cruise down the hwy. Cruising boost at 70 mph is 4-5 psi and cruising EGTs are about 770-800F (outside air temp was about 85F). It's tough to tell as there just isn't a flat stretch of hwy here. It's like either the road is going up hill or down hill every where I go. On some big hills holding 75 mph, it was tough for the EGTs to hit 1000F. Most of the time, when the EGT probe got to the 1000F mark, it was at the top of the hill. Getting into the throttle some, EGTs start leveling off really well at about 1200F (not bad IMO for a full fueled race tune on 190/100s).
Ok well enough yhapping, I know that I don't really have a lot of information here, but I can definitely say that this turbo has some serious potential and I'm excited to see how this thing does with some 175/75s. On a side note, I was extremely surprised how smooth and quiet this turbo was. It does whistle but not nearly as much as I was expecting it to be. It has a nice soft whistle to it and the power comes on really nice and when it does, the whistle goes away. It'll be curious to see how this thing does as it is ran on more trucks.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #2 of 31 Old 08-24-2013, 12:03 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1037 Post(s)
Feedback Score: 6 reviews
Very cool. Are you going to get a tune for that particular turbo soon?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 31 Old 08-24-2013, 12:08 PM Thread Starter
BACKYARDIGAN
Quoted: 4 Post(s)
I forgot to add that there is one thing I found most interesting with this turbo. The compressor wheel is VERY impressive for what it is. The size of 66x90 doesn't really do it justice. The center hub is of a SUPER slim nose design. It has a slimmer hub/nose than a billet stock replacement wheel does. This in turn yields some HUGE blade surface area. The blade surface area of this wheel is every bit as much as a GT4094 wheel, yet the overall size is kept smaller, which should in turn allow this wheel to be spun faster than a GT4094 wheel can easier. Again this is all theory, but like I said above, according to my MAF readings, this thing is definitely moving more air than the other turbos I've data logged so far.
Nate
post #4 of 31 Old 08-24-2013, 12:10 PM Thread Starter
BACKYARDIGAN
Quoted: 4 Post(s)
Yep. I've got an email out to Chris at TSD for a revision. Gonna start with a regular Powermax tune (with my 190/100 fueling parameters) with some specific transmission shifting and see how that does.
Nate
post #5 of 31 Old 08-24-2013, 12:17 PM
RIP Cam!
Good stuff. Looking forward to seeing how it all unfolds.
post #6 of 31 Old 08-24-2013, 12:33 PM
rdunagan's Avatar
I cant remember when I talked with Adrian but is there anything done to the turbine side? that's all im concerned about and again I cant remember what he said about the turbine side
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #7 of 31 Old 08-24-2013, 12:49 PM Thread Starter
BACKYARDIGAN
Quoted: 4 Post(s)
Nope. Completely stock Powermax turbine end. No tweaks at all.
Nate
post #8 of 31 Old 08-24-2013, 01:43 PM
madpowerstroke's Avatar
That's sort of true, but may not stay that way at all. Have a lot of testing to finalize. The compressor wheel is the key to this turbo but measurements are 66mm/90mm there about and the wheel is a slim line design, the 4094va cast wheel has about same surface area, some of billets are still larger.
I will keep the compressor wheel like it is now but the turbine will be played with until I get the exact combination I need.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #9 of 31 Old 08-24-2013, 02:51 PM
rdunagan's Avatar
you know im all about changing the turbine side and testing haha! give me a shout when ya can!
rdunagan is offline
post #10 of 31 Old 08-24-2013, 05:28 PM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
watching this one.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
