Not your typical FICM Tuner Q&A - Ford Powerstroke Diesel Forum
post #1 of 35 Old 08-23-2013, 01:13 PM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
Well this is not your typical FICM tuner vs PCM tuner. I have researched a lot on the subject. First I want to list the things I do know, and then maybe someone can fill me in on the things I dont' know.
Things I do know:
  • Huge increase over stock tuning
  • Slight increase if you already have a big PCM tune (SCT Tune)
  • Inscrease throttle response
  • Dyno proven to increase power
  • Raises egts significantly
  • cannot tune anything except the FICM (not tranny, turbo, etc...)
  • Has the possibility of increasing fuel mileage
  • Some report smoother idle
This link to the gopowerhungry website has a ton of info and is good for reference. It shows dyno graphs, talks about how Ford reprogrammed many trucks and made the trucks slowy, run worse, and get bad fuel mileage. It shows many different combos of how it increases power over stock.
Power Hungry Performance - FICM Reprogramming
Things I don't know:
  • What exactly a FICM tuner does
  • What parameters a FICM tuner can adjust
  • Does a FICM tuner adjust the pulse width
  • How exactly it changes the power
What I have been able to research so far is just he results of FICM tuning, not the cause for the results. I would like to know exactly what it is doing to the FICM that an SCT tuner can't do???
These questions have come about because I have been looking into injectors, nozzles, pulse width, tuning, timing, cylinder pressure etc. I have also had the injectors apart and I was surprised as to how simple they are. What I mean by that is there is not too much that affects the fuel except the pulse width and hpop pressure (fuel pressure and nozzles affect it but are not part of my thoughts) so what exactly can a ficm tuner adjust to make things different? Is it simply making the pulse width longer, faster, harder??? which in effect advances timing, which when combined with stock nozzles and an extreme tune it sounds pretty dangerous. These questions might sound dumb and that is because I am not educated on the subject and have not been able to find the right info to edumacate my self.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #2 of 35 Old 08-23-2013, 01:52 PM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
More good sites but don't quite answer my questions yet
HUGE gains from FICM ONLY tune! - PowerStrokeArmy
PowerStrokeArmy - View Single Post - HUGE gains from FICM ONLY tune!
KC Turbos
peixinho is offline
post #3 of 35 Old 08-23-2013, 02:17 PM
Quoted: 822 Post(s)
Call Gearhead. They are very popular with the 6.0
Corey@CNCFAB is offline
post #4 of 35 Old 08-23-2013, 02:36 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
Ummmm gearhead doesnt tune FICMs ---- going there nets him, well, nothing.
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #5 of 35 Old 08-23-2013, 02:47 PM
Quoted: 822 Post(s)
So you think Matt or Larz doesn't know anything about it???
post #6 of 35 Old 08-23-2013, 02:55 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Originally Posted by peixinho View Post
I would like to know exactly what it is doing to the PCM that an SCT tuner can't do???
Uhm...I'm pretty sure it is doing it to the FICM and not the PCM. That's why you can run a SCT tune along with the FICM tune.
What exactly it does I can't say. I don't know enough about the logic board in the FICM.
RIP Mitch
the Org crew
PGreenSVT is offline
post #7 of 35 Old 08-23-2013, 02:56 PM
Quoted: 5 Post(s)
I didnt say that - I would just ask the guys who do the actual tuning he will get more info that way. I mean I would never ask the guy who fuels the planes to rebuild the turbofan but he may know something about them.
For the record I hear good things about Matt but have never even seen him comment on FICM tuning.
Either way OP good luck.
True Blue Metallic
post #8 of 35 Old 08-23-2013, 03:02 PM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
Thanks I edited it for the typo.
I don't know what it does either... thats what I am trying to figure out. I understand what PCM (SCT) tuners do but I don't understand and can't find a source that talks about FICM tuners
KC Turbos
peixinho is offline
post #9 of 35 Old 08-23-2013, 03:03 PM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
I will ask Matt... he is pretty good about answering my emails and all my questions
KC Turbos
peixinho is offline
post #10 of 35 Old 08-23-2013, 03:06 PM Thread Starter
peixinho's Avatar
Quoted: 217 Post(s)
If a tuner can open the pulse width on a 175/stock injector enough to dump all the fuel... even to the point that people have talked about possibly increasing cylinder pressure past a safe point then that shows that an SCT tuner has the ability to dump as much fuel as is needed. Which leads to my questions as to what the FICM tuner does that an SCT tuner doesn't???
Maybe it can open it slightly farther than the sct tunes. But if you can open them past the safe point then why would you need a tuner to open them farther? Maybe it does it more efficiently... but how?
KC Turbos
peixinho is offline
