Help with Which tune to run - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-23-2013, 06:08 AM Thread Starter
ktyamaha36's Avatar
Hey guys,
I have only tried 2 different Tuners since having my truck. IDP Agg street, and Vivians Loony. Never could get the Loony right, kept throwing the Check engine light so I gave up and reloaded the Agg street. Truck was lifted 6" on 35's at the time. I don't like how the current tune wont lock the TC up until over 55MPH in 5th gear. I also have to back out of the throttle for a couple seconds and then it will lock in. Once its locked in I can drive 50mph just fine, and not feel like the thing is slipping the entire time. My truck sits more than I drive it. And when I do drive it its around town (35-50MPH avg) Stop and go. Does anyone make a tune that can lock the TC 3-5 gear? Or any suggestions as to what I should give a try? Im pretty open to try anything. I just don't want to smoke the tranny running an improper tune for the size tires I have on the truck.
I just raised the truck and put a set of 38's on it...Still running the agg street. I know the Speedo is WAY off now (Can a tuner fix this??), which is also throwing the shifts out of wack.
I have been reading alot about Tony Wildmans tunes, Which tune would you guys recommend me trying of his? Im not looking for anything wild, as Im not studded as of yet. Im looking for some extra power, nice firm shifts, and to actually have the TC lock up without having to drive 60+mph and let out of the throttle to get it to lock in.
Any suggestions on what I should try?
Again the truck isnt a DD. Its more of a weekend warrior !
2005 6.0 CC SWB 4x4
EGR Delete
4" MBRP Turboback Exhaust, No Cat, No Muffler
S&B Intake
SCT Tuned by IDP & Vivian
Sinister Coolant bypass filter
Updated STC Fitting
Blue Spring upgrade
EDGE CTS
9" Lift,
PMF Long arm 4-link kit
Pro Comp Traction Bars
Dual Steering stabilizers
Dual Fox Resi's in the front
20x12 Moto Metal MO962 wheels
38" toyo's
ktyamaha36 is offline
post #2 of 6 Old 08-23-2013, 09:09 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Just my 2 cents I would calculate your actual tire rotations per mile and make sure that is what is set when loading a tune.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #3 of 6 Old 08-23-2013, 09:17 AM
peixinho's Avatar
Quoted: 207 Post(s)
Your tuner should be able to adjust when your torque converter locks up... for example mine was locking up too early, like 45mph and lugging the motor... I ask him to raise it up and now it locks around 55mph which is better for my style of driving.
First for your bigger tires you need to go into the sct tuner and adjust for larger tire size, it should adjust/help/change your shift patterns to adjust for the larger tires.
This should help a little
Tire Revs Per Mile
You might try those before you go switching tunes because you could run into the same problem.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #4 of 6 Old 08-23-2013, 11:12 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
And any of the tuners can lock the TC 3-5 if you ask them to. With 38's you should probably be running 4.30s or 4.56s. That's a lot of tire for the stock 3.73's and a lot of extra work for the trans. With your around town driving the gear change would improve your fuel mileage too.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 6 Old 08-23-2013, 11:37 AM
william_ace's Avatar
Quoted: 2 Post(s)
^^^ Agreed. Change your gears out for a 4.56 and it will feel like a different truck.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #6 of 6 Old 08-23-2013, 07:23 PM Thread Starter
ktyamaha36's Avatar
Gears are on the "todo" list . My last superduty was on 40"s and I swore I wouldn't go bigger than 35"s with this truck...well one thing led to another and I got a deal I couldn't pass up on the 38"s. LOL
I think Im going to throw a set of 22x14 with 37s in the near future...
I will plug in the SCT tomorrow and make some tire size adjustments and see if that helps any. I still want to give another tuner a try just for kicks anyways.
I got home from work today and my new S&B filter was sitting on my door step. Just got it installed and went for a ride. I feel like the turbo spooled slightly quicker. And I Love the extra whistle from the tubo!
2005 6.0 CC SWB 4x4
EGR Delete
S&B Intake
Updated STC Fitting
Blue Spring upgrade
EDGE CTS
9" Lift,
38" toyo's
