03 turbo going quiet?? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-22-2013, 07:38 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
What would cause a turbo that is producing great boost (25 @ 6000') dosnt seem to have any leaks but, it just dosnt sound as loud as when I first installed it. Ecspecially at idle. Is this possible? What would cause this?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 14 Old 08-22-2013, 07:40 AM
Maybe you are getting used to it? maybe load the stock tune and switch back?
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
post #3 of 14 Old 08-22-2013, 07:45 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I might be...truck not tuned yet
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 14 Old 08-22-2013, 09:04 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
What's that like?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 14 Old 08-22-2013, 09:36 AM
Bderick67's Avatar
old age = loss of hearing
Brian
early 2004 F250 CC SB Lariat FX4
* with BPD Oil Cooler/cold weather pack * BPD EGR Cooler * Scangauge II * Blue spring update * Blue wire fan mod *
* Rotella T6 w/ Archoil 9100 * 4" catback exhaust w/5" tip
* 63,5xx miles *
Bderick67 is offline
post #6 of 14 Old 08-22-2013, 01:37 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I wont argue that Im getting old... but the turbo at idle just dosnt sing like it did.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 14 Old 08-22-2013, 02:11 PM
xtremexj's Avatar
Maybe the vanes are stuck so it's not cycling while idling. Mine will cycle between 15% and 85% most of the time and sometimes it will just sit at 67% and be happy there.
2003 F350 SC,SB, 4x4, 6.0L, 5R110, SCT Xcal3 by Innovative and Quick Tricks, zoodad, 05 Accufab elbow, 4" Magnaflow turbo back, 4" ProComp lift, LT315/70R17, custom bumpers
Best time to date: 13.75 @ 96.42MPH
xtremexj is offline
post #8 of 14 Old 08-22-2013, 02:40 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
The turbo could be stuck in the perfect spot. Believe me, it happens. I recently cleaned a turbo in a 6-speed truck that definitely had a negative affect on performance. It's really hard to explain to a customer that their truck runs worse now after I "fixed" it.
The whistle at idle is caused by the vanes being all the way closed creating the most backpressure and it needs the highest VGT duty cycle to do that.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #9 of 14 Old 08-22-2013, 03:47 PM
JustinOOO9's Avatar
Quoted: 543 Post(s)
Garage
I think my hearing got a little worse too because im getting proper vgt% and it just doesnt seem as loud anymore haha no one else thinks that though
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #10 of 14 Old 08-22-2013, 04:20 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Ok if I remember correctly I saw the vgt% on my Edge CTS. What should it read?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
