Ww2 or batmowheel - Ford Powerstroke Diesel Forum
post #1 of 31 Old 08-22-2013, 07:19 AM Thread Starter
Ww2 or batmowheel
Has anyone done any testing between the two wheels.
I've got a powermax that I've installed a batmowheel on a couple years ago.
Would there be any benefit for me to install a single plane 11 blade ww in it instead.
All the hype is starting to get to me. Lol
I'm perty happy with the batmowheel but just wondering if I'm leaving anything on the table by not going to the new 11 blade wheel.
swaan is offline
post #2 of 31 Old 08-22-2013, 07:54 AM
peixinho's Avatar
Quoted: 195 Post(s)
I would say no to the batmowheel... they have gotten some pretty bad reviews, but they were ok when they were the only option.
EDITED to delete false info
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is online now
post #3 of 31 Old 08-22-2013, 08:02 AM
poorboy1964's Avatar
Quoted: 2 Post(s)
Does anyone know what the drive ability differences are between the double and single plane wheels are?
Tom
2003 CCSB 4X4 6.0 Born on 5/03 Tuned by Vivian, 4" Turbo Back Exhaust, Edge CTS w/EGT, Coolant filter. ELC. fuel pressure gauge,
2002 SCLB 4X4 7.3 Stock
poorboy1964 is offline
post #4 of 31 Old 08-22-2013, 08:08 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Batmo sucks. Get the MTW billet 11 blade single plane wheel.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #5 of 31 Old 08-22-2013, 08:19 AM
COAL FIRED's Avatar
I believe and I could be wrong that the WW2 for the powermax is a single plane I know the stock replacement WW2 are dual plane.I got the MTW single plane for my powermax havn't installed it yet but that would be my choice versus the dual plane
2006 f250 ccsb,sct tunes by IDP & gearhead ,studded&deleted,4"magniflow turbo back,coolant filter,ccv reroute,isspro ev2 gauges&scangauge,accufab elbow, stc fitting dummy plugs&stand pipes,sinister diesel reg return,powermax MTW sp billet wheel,S&B intake,AFE ic pipe
Matt
COAL FIRED is offline
post #6 of 31 Old 08-22-2013, 09:02 AM
peixinho's Avatar
Quoted: 195 Post(s)
You are right and I was wrong...
Here is the link to the WW2
http://www.dieselsite.com/wickedwhee...rmaxturbo.aspx
KC Turbos
post #7 of 31 Old 08-22-2013, 09:13 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
While I haven't ran a batmowheel, I have ran the wheel that Charlie listed in the link and compared it to the wheel used in the Stage 1 (they are not the same) and I actually like the current Stage 1 wheel better. I felt that the spool up was quicker and that the cruising EGTs were lower too. This of course is me running my stand by SPD tune for each.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #8 of 31 Old 08-22-2013, 09:18 AM
peixinho's Avatar
Quoted: 195 Post(s)
i wonder why dieselsite runs some dual plane and some single plane...
KC Turbos
post #9 of 31 Old 08-22-2013, 09:41 AM
bondajb's Avatar
I have done back to back runs with a 7x7 vrs a 11b. This was on a 59mm stock charger. Maf , boost and egts all suggest the 11 blade is superior until full boost and the they are sixes.. throttle response was better and did not seem to back fart as much.. the differences were subtle but noticable.
I would believe results would be similar with the 63.5... ???
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #10 of 31 Old 08-22-2013, 09:43 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
He already has a batmowheel guys. IMO there isn't ENOUGH difference between the Batmo and a WWII or an MTW 11 blade to make it worthwhile. Either is a better choice than the cast stock wheel but the flow isn't going be be that much different than the Batmo.
RIP Mitch
the Org crew
PGreenSVT is offline
