why not stud one at a time? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 51 Old 08-21-2013, 11:55 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
Ok so I have heard don't do it but I hsvent seen a reason why if there isn't a current problem why you can do one at a time just hoping for some logic vs just don't do it haha
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #2 of 51 Old 08-22-2013, 12:24 AM
JustinOOO9's Avatar
Quoted: 583 Post(s)
Garage
just read a thread about doing 1 stud at a time the guy would remove one and torq the first sequence i believe 65 ftlbs and then remove and replace 2nd and do torq at 65 then once all were done on each side he did the continued torq sequence on each one. then moved on to the next head.
he said it was called hot potting or something where you leave oem studs in one at a time to prevent headgasket from lifting and you will need to dent up fire wall and cut the top of a stuff of while using something to hold bottom to remove it.
Studs one at a time, easier than I thought....
here it is.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s, JW Vbody.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 51 Old 08-22-2013, 01:06 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Dont do it. You will end up re doing it the proper way shortly after
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 51 Old 08-22-2013, 01:28 AM
gotta_gofast's Avatar
Quoted: 62 Post(s)
...even if it worked half the problem lies in the cylinder head. I know my heads were out 0.009" so even overtorqued studs wouldn't pull that together for long.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #5 of 51 Old 08-22-2013, 01:38 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Yeah nothing should be over torqued. By over torquing you make the bolt (or in this case the stud) work outside of its working limits.. Thus leading to improper clamping and reduced tension etc.
MrOneEyedBoh is offline
post #6 of 51 Old 08-22-2013, 03:02 AM
I haven't read about anybody having head gasket issues after doing studs one at a time. I wouldn't recommend torquing to 65 and then after each is in place working them up to full torque. The heads/gaskets are already set, pull one out and go full torque on the stud right away. It couldn't hurt to go back through after the last stud is in and retorque them all in sequence.
WLDHRSE is offline
post #7 of 51 Old 08-22-2013, 03:30 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Your head gaskets may be in the process of failing and you not know it, the truck have no symptoms yet. Studs may hold off a little longer or letting the head back of to 65psi might finish the job. If you recently had head gaskets installed then maybe I'd go for it but if you have a lot of miles on them I wouldn't do it without new gaskets. If you have to do it torque the bolt all the way as you replace each one as Cliff says above.
RIP Mitch
the Org crew
PGreenSVT is offline
post #8 of 51 Old 08-22-2013, 05:00 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I guess its a question of time and money and want to and availablity of a good shop that can grind the heads. I did the 1 at a time and have yet to have any issues. I had the money to do the job, but the nearest place I could take the heads to is a 2 hour drive. So I tossed the dice and so far so good.
And just because you pull the head and all looks good and you do run what ever head gasket that everybody has decided is the "best of all time,at this time" is dosnt mean that they wont blow again.
The only down side is now I wish I could run a good tune. And Im nervous about throwin the dice again.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 51 Old 08-22-2013, 06:58 AM
Quoted: 2 Post(s)
Unless you know the clamping force of each original bolt and install each stud to that amount, it's a crap shoot. By loosening the bolts you are doing the exact same thing as what happens when overheating the engine, sometimes a re-torque works and sometimes it doesn't.
03 F-250 6.0 Black/Gold Lariat CC SB FX4
jsm180 is offline
post #10 of 51 Old 08-22-2013, 07:55 AM
COAL FIRED's Avatar
I did the 1 for 1 because i couldn't justify pulling the heads at 20k truck now has 55k on it with no problems and it has been tuned the whole time.What i did is took a dial torque wrench and loosened one bolt it took 165fts so that is what i used for my initial torque after replacing all the bolts then I did my final torque.As far as the proper way thats your decision I have done several head stud jobs the right way if thats what you want to call it its not to difficult.It's a roll of the dice but i was willing to try it and it has worked so far.Cost me the price of the studs and some time.
2006 f250 ccsb,sct tunes by IDP & gearhead ,studded&deleted,4"magniflow turbo back,coolant filter,ccv reroute,isspro ev2 gauges&scangauge,accufab elbow, stc fitting dummy plugs&stand pipes,sinister diesel reg return,powermax MTW sp billet wheel,S&B intake,AFE ic pipe
Matt
COAL FIRED is offline
