Help What FASS Fuel Pump SHould i get? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-20-2013, 08:18 PM Thread Starter
Fatal129's Avatar
All my truck adds are in my signature but the big one to say is my injectors are 190/100 running stock turbo but i got my tunes from innovative. Looking at the new FAAS Titanium Fuel pump but i didnt know what level i should get my truck i dont want to by the extreme and not be able to touch its potential and i don't want to buy the moderate and it not be enough. Also with this upgrade should i get bigger fuel lines or a fuel sump? Thank you
Specs at moderate
125 GPH @ 55 psi
Specs at extreme
200 or 220 GPH @ 55 psi
03 F 250 FX4
SCT Touch Screen Xtreme( Agg, Xtreme Street, Xtreme w/ Lope by Innovative)
banks monster exhuast
banks 6 gun chip ( Disconnected and wanting to sell)
10 inch Bulletproof lift
4 inch downpipe from turbo
20x12 rims on 38 MTZs
dual fabtech steering stabilizers
ARP Head Studs
EGR Delete Kit with down pipe
190/100 Thoroughbred Injectors
T500 HPOP
FCIM tune 100
Fatal129 is offline
post #2 of 4 Old 08-21-2013, 07:41 PM Thread Starter
Fatal129's Avatar
BUMP Plz help me out
03 F 250 FX4
ARP Head Studs
T500 HPOP
FCIM tune 100
Fatal129 is offline
post #3 of 4 Old 08-22-2013, 03:52 AM
I don't know anything about that specific pump, but unless it is a completely new design, my recommendation would be put it back on the shelf and run away from it as fast as you can. FASS pump failures is what led everybody to Airdog.... failures! Same design, same problem. If what you got is something new and made for high pressure, it's going to get a lot of attention quickly.
WLDHRSE is offline
post #4 of 4 Old 08-22-2013, 09:52 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I'd consider the Fuelab setup. They don't have a kit for the Powerstroke so you'd have to do your own wiring and plumbing but if you can't handle that IMO you shouldn't be messing with your truck.
And yes, 1/2" feed and 3/8" return minimum and a sump is preferred.
RIP Mitch
the Org crew
PGreenSVT is offline
