So far with the efr - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-19-2013, 08:03 PM Thread Starter
So far with the efr
I've had the setup in the sig for a few thousand miles now. I'm still diggin it. It is a little dirtier from a dig than a stock tuned truck, but it seems to be lighting around 1650-1700 and then it's on. Averaging about 16.5-17.5 overall, depends on how much in town driving I do.
I can tow about 7000lbs safely, egt's never over 1120, I tried 12k, but it was very prone to top 1250 and would have to back out. This was with a heavy tow tune on both accounts.
Overall, I'm happy with it, and have no regrets.
07 ccsb 4x4, , swamps 58v(mild flash), rr, a1000, 225/50's, ported and polished heads, outlaw diesel headers, ported intake, dashboss fuel/egt, studs, twizted billet tranny
dfish1247 is offline
post #2 of 7 Old 08-20-2013, 02:52 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
That sounds like one sweet setup to me. Glad to hear it's working out for you.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 7 Old 08-20-2013, 05:43 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
Sounds like the efr is working out pretty well for you. Are you using a higher stall converter? Sounds like it lights off pretty quick.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #4 of 7 Old 08-20-2013, 08:02 AM Thread Starter
I'm using a 2000 stall. As for boost, it will lug itself out of a hole, but its very dodgish in nature, if you stay on the charger it will snap straight to 45psi and your off.
post #5 of 7 Old 08-20-2013, 08:07 AM
Turbos = Witchcraft
TooMuch03's Avatar
That's awesome. Seems like that 8374 is a good turbo for an all around street truck.
2003 F250 6.0
Compounds FTW!!!
post #6 of 7 Old 08-20-2013, 09:58 AM
pizza pig's Avatar
try a race file yet? hows smoke output and hazing?
pizza pig is offline
post #7 of 7 Old 08-20-2013, 10:37 AM Thread Starter
Yes, I do run around on a race file. Once lit, the smoke is maybe 10% more than a tune only truck at wot. Nothing to be ashamed of, for me anyway. Lag is a hair more than pmax/stock stick truck, a .83 housing would fix that I think, but it works just fine for me as is. The highest egt's I've seen are 1525, fine by me as well.
My towing file smokes if your to hard on the throttle pulling out. Other than that, none at all. The mileage sucks on it though, about 13 overall, so I use it if I'm towing only.
