New turbo or new sticks??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-19-2013, 07:55 PM Thread Starter
southern raised's Avatar
Hey i have an 03 6.0 with egr delete, oem gaskets and arp studs sinster oil cooler, custom tuned SCT, K&N intake and str8 piped exaust into stack
Im looking into possible powermax stage 2 turbo or 175/stock injectors or 175/75 injectors im building my truck SLOWLY. im gonna get a fuel pump airdog or fass, and im looking into the turbo or sticks which do u guys recommend doin first?
Sent from AutoGuide.com App
southern raised is offline
post #2 of 6 Old 08-19-2013, 07:57 PM Thread Starter
Do i need to back it up with a fuel pump? Im right around 57-61psi and idel right now
post #3 of 6 Old 08-19-2013, 08:05 PM
Supposedly a rr with the stock pump will suffice.
I'll ask if you have a power goal as that will save you work and money in the long run. Just skip buying small crap and working your way up if eventually want a monster.
07 ccsb 4x4, , swamps 58v(mild flash), rr, a1000, 225/50's, ported and polished heads, outlaw diesel headers, ported intake, dashboss fuel/egt, studs, twizted billet tranny
dfish1247 is offline
post #4 of 6 Old 08-19-2013, 08:16 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
Skip the air dog or fass .... Get you a 6.4 pump as a lift pump. It sounds like the 6.7 may work too juggernaut is trying it out soon. The stock hfcm will keep up with 175/75s especially with adding the 6.4 or 6.7 pump as a lift pump. A RR would make it that much better.
As for which to do you need to set your goals first before buying parts. Jmo
Todd
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #5 of 6 Old 08-20-2013, 12:49 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 132 Post(s)
A strong reliable fuel system is ALWAYS a requirement for a 6.0L motor. So build/buy whatever you can afford.
I'd suggest a ported intake manifold and a turbo of your choice. Injectors can be added later down the road.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #6 of 6 Old 08-20-2013, 02:22 AM
snafu!'s Avatar
Sound advice. If you can only do one mod at a time go with a turbo first. A ported manifold can cure cancer and will save the rain forest, so I've been told. Lol
But in retrospect my build would have been very different if I knew the trans would not hold up to more than 500hp. I was counting on my trans holding up for a while until it was built then add more HP. It lasted less than a day with 175/75 and hybrid. Save your money and build your truck once. It will be much cheaper in other long run. I am looking paying for injectors and a turbo twice now, I already have fuel system that can support 400cc injectors. My truck is already stupid fast on the street but there always quarter throttle right. Lol
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
