MTW and it's WAIT TIME and Product quality::::: - Ford Powerstroke Diesel Forum
post #1 of 112 Old 08-18-2013, 03:35 PM Thread Starter
madpowerstroke's Avatar
Hello everyone, I would like to apologize about the problems that I have been having with wait times on all the turbos. I listen to what people say and I care, I have MTW a spot that every small company gets to and made it to the spot quick. A lot quicker then I thought it would happen. I can either stay the way I am and stay small, or invest money into the company and make it into a premier turbo company.
I have decided to invest money and grow the company into the best option to go with and highest quality. First it will take a little of time to get things set up, and I have been working very hard to get them set up to have everything ready within two months time.
Wait time, I will be ready within one month maybe shorter depending on when the supplies I have ordered get to me. I have over 20 brand new center sections, 30 brand new turbos, and 30 brand new center sections coming. Along with over 100 unison rings, and other parts, why? I have a goal to have the turbos sitting on the shelf ready to go, at least 10 stage 1, 6 new stage 2, 5 stage 3, and 5 stage 4.
Quality I have out sourced the compressor housing from my machinist and have gotten two machine shops to take care of the load of supply. The compressor housings will be CNC machined to the highest standards. The compressor housing and wheels are not a continuous radius they actually have 3 separate radius that make it up. I believe that the bridge port mill with a cutter made to the three angle is important, but the CNC will be much better and provide a better quality. So shops use a lathe which I don't agree would be the best way, and very hard to reproduce the different angles. My machinist will be kept busy with other projects.
Balancing is one of the other things that have come up, yes I will have a VS balancer coming to me as soon as they build one and send it to me. Do I know how to use one? sort of I use a VSR balancer on the jet engines I have balanced in my 25 year time as a aircraft mechanic, same balancer just the VSR is more difficult to use. I will be balancing the rotating assembles with the VS balancer, and I will also be sending turbos to be balanced by a VSR balancing machine. The turbo VRS balancer is spun to 100,000 rpm and balanced, and once I get things in order all the turbos will have a balance VSR balance sheet with them.
The turbo will also get Garrett repair kits with them, and have the upgraded 360 degree thrust bearings added to all.
I have been very busy to get all these things ready and will be in place, I will continue to provide the best quality, less wait time, and best performance products I can. I will be expanding the shop and then getting a new one to move in. I thank the customers for a chance to supply them, and hope to provide excellent customer service to new customers.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #2 of 112 Old 08-18-2013, 04:04 PM
jmeaby's Avatar
Quoted: 16 Post(s)
I think we need a like button on the forum haha keep up the good work
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #3 of 112 Old 08-18-2013, 07:13 PM
You copied my 360 thrust mod, I might just have to complain about it for a year or two now... darn
NRHX2009 is offline
post #4 of 112 Old 08-18-2013, 07:53 PM
And your going to balance assemblys now, thats copying.
NRHX2009 is offline
post #5 of 112 Old 08-18-2013, 07:55 PM
I hope your copy business goes well, maybe you can make posters and flyers for my products.
NRHX2009 is offline
post #6 of 112 Old 08-18-2013, 09:04 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
In before lock!!!!
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #7 of 112 Old 08-18-2013, 09:25 PM
USAFBowman's Avatar
I had been reading all the good stuff about barder lately and was half tempted to start looking at those turbos.... But these comments just threw that out the door. I'm sticking with Adrian for when I get my turbo built. May be a while. But Adrian seems much more mature and a business man willing to make sure his customers and happy and get exactly what they want. Keep up the good work Adrian. Looking forward to doing business with you in the future.
PS: congrats on taking the next step with your business Adrian.
USAFBowman is offline
post #8 of 112 Old 08-18-2013, 09:27 PM Thread Starter
James, not copying a thing, 360 thrust bearings is a common mod. As far as balancing that is also not coping I will have VSR balancing which is better then the VS balance, I just answered all of your faults with my product and upped the ante. You have your way of doing things and I have mine, you bore the housings your way and I get mine CNC. Again all the things that were in the works before you but had to bring them out faster. I guess making wait time to zero wait with product on shelf, sticking balance sheets with the turbo, putting a trouble shooting guide are all your ideas also.
It's all part of competition, and like I stated before you do it your way turbine wheels and such and I will be doing it my way, which by the way here's a little heads up, I have my own and exclusive turbine wheels being made gt4088 wheels but with the thickness of the 4094va for reliability. I welcome you to the 6.0 powerstrokes as a option and keep your products coming.
I can send you a poster and flyer of mine if you like, and hope your business does well also.
post #9 of 112 Old 08-18-2013, 09:34 PM Thread Starter
I thank you very much, don't be so hard on Barber he is responsible for pushing me to the next level, and for that I thank him. I want to be able to offer the best product, at the best prices, put my future customers and present first.
post #10 of 112 Old 08-18-2013, 09:42 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
very nice adrian i have been hoping and praying the stage 2 would come back out. soon as barder turbos come out i did read reviews and thought about it but then still thought back at stage 1. now that i hear stage 2 is gonna return im gonna have to wait and see some reviews before i say stage 1 or 2 and i like that there will be no turn around time that is honestly what has been holding me back. this is my only vehicle so i cannot have down time longer than a day or two. i think the no wait time will help many people.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
