billet wheel? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 08-18-2013, 01:08 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
billet wheel?
What are the advantages or disadvantages to putting one in my stick turbo is it worth 285 out the door at harder turbos anyone like or hate one of the bullet wheels
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #2 of 20 Old 08-18-2013, 01:43 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
And any recommendations for a wheel.
04 f250 cc sb.
jmeaby is offline
post #3 of 20 Old 08-18-2013, 01:45 PM
5fifty's Avatar
Its not a bad upgrade. Might make your turbo spool a little faster and slightly lower egts. It is worth it but IMO I would save up a couple hundred more and send the turbo off to MTW.
I have one in my stock turbo but my build funds and time ran out when I did my bulletproofing. I dont regret installing it but will be going with a larger turbo soon to get the most out of my 155's. My
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #4 of 20 Old 08-18-2013, 01:49 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
How does it clean up those 155/30 injectors
04 f250 cc sb.
jmeaby is offline
post #5 of 20 Old 08-18-2013, 01:55 PM
I would just get a powermax and throw a billet wheel in there... You will get the turbo fast, its a new turbo, and it will handle the 155/30's with no issues.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #6 of 20 Old 08-18-2013, 02:05 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
I have stock intectors and right now I'm not trying to go to over the top yet till I stud the truck. So I'm just looking fir reviews on stock turbo with new wheel
04 f250 cc sb.
jmeaby is offline
post #7 of 20 Old 08-18-2013, 04:00 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
Anyone else do this to there truck? Trying to stay budget friendly right now till I finish some stuff.
04 f250 cc sb.
jmeaby is offline
post #8 of 20 Old 08-19-2013, 12:47 PM
COAL FIRED's Avatar
I installed one in an 03 for a guy I was suprised how well it performed but i wasn't expecting much.Noticed a little better throttle response and it definately built boost quicker I paid $200 for dual plane billet wheel i wouldn't pay 285 for one.As for egts he didn't notice much difference overall I think its a decent bang for the buck
2006 f250 ccsb,sct tunes by IDP & gearhead ,studded&deleted,4"magniflow turbo back,coolant filter,ccv reroute,isspro ev2 gauges&scangauge,accufab elbow, stc fitting dummy plugs&stand pipes,sinister diesel reg return,powermax MTW sp billet wheel,S&B intake,AFE ic pipe
Matt
COAL FIRED is offline
post #9 of 20 Old 08-19-2013, 12:54 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Yep, the dual plane billet wheel sucks compared to the 11 blade single plane version. I had a guy put the dual plane version in his 04 and while towing he could get some slight surging, ran slightly higher EGTs, spool up was the same, and power was the same as stock. I then had him put in the 11 blade single plane version for the 03-04 turbos and he saw (IIRC) about a 100F drop in EGTs, quicker spool up, better low end response and power and NO SURGING. We've just had great success with the 11 blade single plane wheels in our turbos.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #10 of 20 Old 08-19-2013, 01:04 PM Thread Starter
jmeaby's Avatar
Quoted: 16 Post(s)
The 285 is also for balancing plus I feel like I would mess up taking the turbo apart haha not sure though. I know I can take it off the truck
04 f250 cc sb.
jmeaby is offline
