super panty dropper a must have - Ford Powerstroke Diesel Forum
post #1 of 21 Old 08-18-2013, 07:14 AM Thread Starter
Thought I would do a little review and no politic games on how the tunes I have tried this morning... After getting back in town from work i loaded all these tunes to try. I had run the srlxx tune from matt and is a great tune. Shifts good, great power and definetly will keep it loaded in my sct.
Loaded The super panty dropper tune from chris and holy freaking cow.... The power was increased from the srlxx to the point where I was shocked. Shifting was spot on and the truck moved around effortlessly like a pocket bike with a big bore kit in it- this will be my daily tune now, he wrote me one with early lockup for the track but have not tried it yet..... Boost increased from 32 psi on srlxx to 35-36 on the spd tune. The spd tune hardly smokes also which i thought was strange as the srlxx i could clear a whole lane out with smoke taking off. The p-max rises again with zero lag on the spd tune(srlxx had no lag either)
Now onto the other tunes... Sorry but eric and tony's tunes were weak as can be and my truck hated them.. Not impressed at all with there extreme tunes. Nothing else to say with them other than they are similar to canned tunes.Anyways just short and sweet reviews of the extreme tunes. Going back to work for a couple hours now...
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #2 of 21 Old 08-18-2013, 07:19 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I thought Chris quit writing tunes unless you had it live tuned? I'd like to try the SPD tune but hadn't tried to get one.
dhanna6powerstroke is offline
post #3 of 21 Old 08-18-2013, 07:19 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Nice review!! Just goes to show how tunes react different in different trucks.
So does this mean TSD is doing emailed tunes agaian? Or were these tunes that you ordered prior to TSD stopping emailed tunes?
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 21 Old 08-18-2013, 07:30 AM Thread Starter
He is doing tunes again via email yup... What a good thing for sure... I assume he will stop again once he gets swamped with emails lol
bpd
Warren comp trans
04cr450 is offline
post #5 of 21 Old 08-18-2013, 08:31 AM
elchaseo's Avatar
Quoted: 8 Post(s)
What is he charging for tunes?
2015 F250 Lariat- CAI, CCV Reroute....more to come
elchaseo is offline
post #6 of 21 Old 08-18-2013, 08:58 AM
sargar's Avatar
I'll add to this.....
I've been running the SPD for about a year now in conjunction with PHP's Atlas 80 FICM tune. Holy Cow is about accurate. My truck feels like a gas engine in a small car, if I get ready to pass I have to make sure I start changing lanes early because the gap closes quick. Mine will smoke some on the bottom but cleans up quickly. I am running Chris' early lock up version, my only complaint is every once and a while it will lock early while I'm not making boost, then it lags a smokes like a Cummins. A stab of the throttle or push of the tow/haul button fixes it. Chris' tune made my truck useless in the rain, even fresh tires won't grip, I just have to roll into it and stay around 1/4 throttle until I have some speed. And the best part, I'm hand calculating about 16.5 MPG out of it back and forth to work, I'll get about 18 out of it unloaded on the intetstate. I love this tune!
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #7 of 21 Old 08-18-2013, 09:03 AM
Besides possibly having an exhaust an intake, what other mods are needed to run an extreme tune like this? Head studs? Turbo upgrade? Built tranny?
Sent from AutoGuide.com App
that_dude is offline
post #8 of 21 Old 08-18-2013, 09:18 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 954 Post(s)
Feedback Score: 6 reviews
I am assuming the panty dropper tune is not TTY head bolt friendly.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #9 of 21 Old 08-18-2013, 09:19 AM
sargar's Avatar
I'm pushing the limits of sanity as far as the stereotypical 6.0 horror story goes. My tune is for a studded truck but I'm on TTY bolts. I've got a 5" straight exhaust, S&B cai and a Wicked Wheel II in my stock turbo. I do monitor fuel pressure and EGT. I draw my fuel from a sump rather than from the stock tank unit. My trans is stock too with the exception of a GoGo Diesel direct clutch solenoid, synthetic fluid and a dieselsite spin on filter.
DISCLAIMER....run my receipe at your own risk, mine could puke tomorrow. I'd hate for someone to think that since I've been lucky, that they would too.
sargar is offline
post #10 of 21 Old 08-18-2013, 09:34 AM
paintballbryce's Avatar
Where can one purchase this tune and for how much?
2006 F250 Bulletproofed - SOLD
2008 F350 King Ranch
Stock for now
paintballbryce is offline
The Following User Says Thank You to paintballbryce For This Useful Post:
2 Power (11-17-2014)
