Upgraded Boost Tubes and Intake Elbow? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-17-2013, 01:11 PM Thread Starter
pwrstroke6john's Avatar
I am looking at picking up a aftermarket Intake elbow for my 6.0 and am wondering if it will be noticable. If I do go ahead and purchase one I was looking at getting the MBRP model that also sells a turbo to intercooler model. The only issue is I know the next step is a aftermarket intercooler and then those tubes may become spare parts.
thanks for any experience or advice in advance
2005 F350 crew cab short box
6 inch pro comp lift
35x12.50-20 Nitto Trail Grapplers
Moto Metal Rims
5 IN MBRP Turbo Back Straight Pipe - 6 IN Tip
AFE Cold Air Intake
SCT Tuner
Coolant Filter
EGR Delete
15% Window Tint
6000k HIDS
Bushwacker Flares
Buckstop Front Bumper
Custom Rear Bumper
Weatherguard Box
pwrstroke6john is offline
post #2 of 6 Old 08-17-2013, 02:25 PM
USAFBowman's Avatar
For hot side (turbo to intercooler) when I do mine I will probably do the MBRP one. A mishimoto intercooler. Then for cold side (intercooler to intake) I would go with NO Limit CAC.
USAFBowman is offline
post #3 of 6 Old 08-17-2013, 03:08 PM
snafu!'s Avatar
There wont be a noticeable difference with an intake elbow, they just look nice and have ports tapped. I would reconsider the mbrp CAC tube, it is 3.5" and cause slower spool.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #4 of 6 Old 08-17-2013, 07:42 PM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
Mbrp is a larger diameter tube I believe spool up time may suffer a bit unless you are going to upgrade turbo and/or injectors.
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #5 of 6 Old 08-17-2013, 07:43 PM
Quoted: 5 Post(s)
TREE'D .... Shoulda read all replys first lol
True Blue Metallic
post #6 of 6 Old 08-17-2013, 07:56 PM
With my Banks setup which has 3.5 pipes it spooled alot better. So I have to ask if you saw this in person on your truck. just asking.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
