Need input on HG/Heads job! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-16-2013, 05:52 AM Thread Starter
jmoney330's Avatar
Well guys, as 1puglife on youtube would say, my truck is dinked. It's all chooched out
Anyway, not this coming week, but the next I'll be taking my truck in for the head gaskets and what have you. Just a few questions for y'all out there;
Has anyone used Quick Tricks Auto for their gaskets and/or replacement heads? They seem pretty cheap (Gaskets @ 155/ea and new Heads @ 800/ea if I remember correctly). Are the OEM parts or aftermarket?
Secondly, my FICM is choochin it at about 35v on start up so while I have everything apart I'll fix it. My oil cooler deltas are usually 10* apart but while I'm in there, what the hell right? Has anyone ever used the Dorman replacements? I can get a hell of a deal on them. Right now on Amazon the FICM is like $116 shipped and the oil cooler is $121 shipped. That's cheap! I could possibly even get it cheaper than that. But regardless I hear mixed things about dorman, anyone ever tried either of those products?
I think I'm also going to go ahead and do a coolant filter. Which one do you guys recommend? Sinister or Dieselsite or? I'm also going to do the flush and switch to cat EC-1 and blah blah. I don't ever want to have to take this engine apart again.
Also what about STC fitting, stand pipes, dummy plugs, etc. Y'alls input would be real helpful. Thanks!!!!
Sold
2005 F250 SD SCLB. OEM Gaskets, ARP HeadStuds, EGR Delete. BulletProof Diesel 6-phase 58v FICM. Sinister Coolant Filter. STC Fitting, Blue Spring, Stand Pipes and Dummy Plugs. 35" Cooper Discovers on Ford Factory Rims. GlowShift Max Tow gauges. 3" Lift. SCT Livewire (Canned Tunes at the moment, soon to be Looney Tuned). Kensun 6000k Headlights & Foglights. Zoodad Mod. Problem child
jmoney330 is offline
post #2 of 5 Old 08-16-2013, 04:04 PM
gotta_gofast's Avatar
Quoted: 62 Post(s)
Say NO to dorman. Use a genuine Ford/International oil cooler and check out ficmrepair.com for the FICM. Any competent 6.0L friendly shop will know the usual updates and upgrades for a reliable motor. A coolant filter is a good idea, I have a dieselsite one on my truck but in all honesty they do about the same thing.
Unless your heads are unrepairable, I suggest having a reputable machine shop inspect and machine your heads.
This post wouldn't be complete until I pointed out the EXTENDED TOW MIRRORS!
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #3 of 5 Old 08-16-2013, 05:21 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Then don't use cheap Dorman parts. Use oem parts. Send the FICM to Ed at FICMRepair dot com or get one fro Vivian if you want to stick with a stock FICM. Get one from BPD if you want something better than stock.
Yes do the standpipes and dummy plugs. That's a no brainer. The SCT fitting depends on the year of your motor. If it has the old style fitting by all means update it.
IMHO the only coolant filter worth buying is the IPR High Flow coolant filter. It obsoleted all the others.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 5 Old 08-17-2013, 03:47 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Uh-huh.. Its nice with the S mesh and magnet in the filter. And its a no brainer that it flows more, even the hose size is more then double the ID of the other filters.
MrOneEyedBoh is offline
post #5 of 5 Old 08-17-2013, 03:56 AM
JustinOOO9's Avatar
Quoted: 553 Post(s)
Garage
got my ficm from ficmrepair.com and its perfect I did the exchange program since my truck is my daily driver. as for oil cooler go with OEM there arn't very many parts ford did right but one was the oil cooler replacements... while your there look at stand pipes and stc fitting in high pressure oil system and do the chemical flush before replacing the coolers. if you smog get bulletproof egr cooler or delete if you dont have emissions
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
