Powermax Turbo/ High EGT's - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 08-15-2013, 04:51 PM Thread Starter
I replaced my turbo with the PowerMax and I'm seeing to high of EGT's as compared to the stock turbo, just with highway driving with no load. On some of the slight hills we have around here I'm seeing 1100-1350 on a regular drive with cruise set at 70 mph, flat it runs about 750- 900 at 70mph My stock turbo would only pull 750-1050 EGTS on the same drive, is this normal for a stock truck with only the Powermax and 4 inch staight Pipe ? I have the SCT with lonney tune and havent done the EGR delete yet but thats coming next with the head studs,oil cooler and intake. any thoughts on this would be great as I'm just starting to upgrade the truck
BP-1 is offline
post #2 of 11 Old 08-15-2013, 05:48 PM
JGman141's Avatar
You need to get your tune upgraded for the powermax. Until then it will run hot
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 11 Old 08-15-2013, 08:33 PM
Quoted: 97 Post(s)
Feedback Score: 3 reviews
I had a similar experience when I added my Powermax. I also had a lot of low end lag. I ended up going with Matt's 8k tow tune and it helped with the lag and the EGT's.
2006 F250 Carli 4.5" Pintop, Carli LT airbags, Top Gun Customz dual steering stabilizer, 4.30 gears Toyo MT 37's, Powermax, SCT X3 w/ Matt's 8k Tow tune, BPD 53 volt FICM, DC Power 185 alt, PMM coolant filter with Rotella ELC, Edge Insight CTS, MBRP 4", Line X'd bumpers, grille, and tonneau cover
villestrip is offline
post #4 of 11 Old 08-15-2013, 08:49 PM
RanchStroke's Avatar
Egt's
bp-1 I am seeing the same results so I am installing a mtw billet wheel and adrian at mtw is working with me in order to get my egt's in check.
2006 F250 Kingranch CC 4X4- Totaled 4/28/15 RIP
2012 F250 Kingranch CC FX4- Stock
2000 F250 XLT SC 4X4- FF Stage 1 Injectors, 38R and WW2, Swamps IDM, 6 pos chip from Tony at TDP, CTS Gauges, 4'' MBRP, S&B intake, 20'' Fuel's-305 Dura Grapplers, Smoked Recon light's, HID'S 5K, Ranch hand bumpers
RanchStroke is offline
post #5 of 11 Old 08-15-2013, 09:48 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
That's some high egts man. I'd be looking for a exhaust leak at the collector and the turbo. Start your truck and put your hand around it and feel for air. Possibly exhaust manifold or up pipe leak as well. Or your tuning sucks
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #6 of 11 Old 08-15-2013, 09:55 PM
JustinOOO9's Avatar
Quoted: 501 Post(s)
Garage
aftermarket turbo with high horsepower tune... Custom tune seems to be a common answer. have you noticed a lower egts with a lower horse power tune? also with my stock gearing and 35's 75mph is close or above 2k rpms on a 4k redline tach...
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #7 of 11 Old 08-16-2013, 03:53 AM
XL trash...
Merc82's Avatar
Quoted: 296 Post(s)
Yes I have been here. The right tuning and a MTW billet wheel made it manageable for me.
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #8 of 11 Old 08-16-2013, 03:58 AM Thread Starter
Thanks for the help, will be looking into a few things this weekend, and yes it is custom tuned for the Powermax from Vivian but it is the lonney tune, and the EGT's were about the same with the lower canned SCT tunes, So maybe just an exhaust leak I hope, anyway thanks for the replys
BP-1 is offline
post #9 of 11 Old 08-16-2013, 08:48 AM
madpowerstroke's Avatar
Let me explain on why the EGT's are higher with the Powermax Vs the stock turbo, or some of the other aftermarket turbo. I'm not bashing the Powermax this is just the facts.
The reason is simply that the combination of the compressor wheel the 63.5mm/88mm dual plane cast wheel in the Powermax combined with the 72.5mm/66mm 10 bladed turbine wheel is the cause of the problems( lag, dead spots, and high egts.) The Powermax shares same turbine wheel as the 03 turbo, but the 03 has a 59mm/82mm dual plane compressor wheel. The weight difference of the compressor wheel and amount of flow is what makes the difference, not just between these turbos but any turbo combination built.
By replace the cast wheel with a billet single plane wheel on the Powermax you will decrease weight, and increase air flow which will help the problems with the Powermax. Tuning also helps since the VGT duty cycle needs to be closed more to let the turbo spin faster at the lower RPM while at cruise to reduce the EGT's. The secret is to find the right combination for compressor, turbine wheel size that the 6.0 powerstroke exhaust pressure can handle at low RPM to lower the EGT's at cruise and still give you all the rest of the power you need. The stock injectors will also make the Powermax run hotter, vs larger injectors that can increase the exhaust pressure through increase compression in the cylinders, and of course a ported manifold will also help since the back cylinders are now running more efficient which would increase exhaust pressure to help move the larger turbine wheel. Hope this helps explain what is going on and how I have figured out how to mod a Powermax to make it work more efficiently, and not just by the compressor wheel but other things that I have found out.
cowens677 likes this.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #10 of 11 Old 08-16-2013, 08:57 AM
Eric@PTP's Avatar
Any time you move up to a larger turbo and change nothing else ( ie Injectors or Tuning ) you're going to have some lag and higher egts. Larger turbos to not lite as fast as smaller turbos do, it takes more inertia to move a larger object thats just simple physics. If you get a tuner tailored for the turbo upgrade you'll be fine. You need to remember its a performance upgrade not a stock replacement.
1-888-516-4644
GO NAVY
Eric@PTP is offline
