Oil cooler replacement - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-15-2013, 03:24 PM Thread Starter
585Amarillo's Avatar
I'm just wondering is the stock oil cooler the best and reliable if i replace it and add a coolant filter. and if i should also get a external oil filter ? and information would be great. I already have a egr delete
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #2 of 9 Old 08-15-2013, 03:45 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I would argue that the "best" that you could do is the Bullet Proof Diesel oil cooler. For a couple reason's. 1 It will never clog again. Well I have yet to read or hear about one clogging anyways. With the OEM you just cant say that. Im sure your gonna get somebody on here that will tell you the have 4 million miles with the original FORD gold coolant and have never had a issue yet....but for that one guy there is gonna be countless OEM nightmares.
2.It just cools and filters better. And if you combine the set up with a bypass filter man your oils gonna be happy....happy oil,happy injectors.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 9 Old 08-15-2013, 04:09 PM Thread Starter
Im going to be flushing and switching to cat ec-1 coolant
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #4 of 9 Old 08-15-2013, 05:06 PM Thread Starter
how does the kit work for you kinni?
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #5 of 9 Old 08-17-2013, 04:53 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
The ONLY issue that I have had yet with the BPD oil cooler is reeley more of my truck fault than the kits fault. With the BPD set up you totally remove the coolant from any contact with the oil. So if I understand correctly the truck uses the coolant temp to monitor the oil temp. Or at least as watches the coolant temp as to know when to kick the fan on and this wll keep the oil temps down. So now I gotta retune the truck to bring on the fan to a lower temp. But this is no big deal and BPD put on her that the will send this retune for free.
Like I said its more the truck than the kit.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 9 Old 08-17-2013, 05:53 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
If you have the money for the BPD remote oil cooler it is hands down the best option for your oil cooler. If not running ELC coolant, get an IPR coolant filter, and an oem oil cooler and you should be pretty reliable. There is still a small chance that the oem cooler could clog or rupture but you will never be 100% free of that with the oem cooler.
RIP Mitch
the Org crew
PGreenSVT is offline
post #7 of 9 Old 08-17-2013, 06:47 AM
If your system is clean and you have an egr cooler delete the best option is the stock cooler, but you have to get the system clean if it has not been maintained well. The BPD has issues with getting enough air to the cooler on some trucks and if you are in a cold climate you need the cold weather kit. There are limitations with both, weigh them and decide. Neither will harm your truck if done properly.
On my truck the stock cooler works fine, did the Monteagle Mountian in Tn pulling the 5th wheel and saw max oil temp of 226* with air temp of 90* and ac on. The rest of the 3000 mile trip EOT was 206 and ECT 196 average.
03 F-250 6.0 Black/Gold Lariat CC SB FX4
jsm180 is offline
post #8 of 9 Old 08-19-2013, 02:18 PM Thread Starter
i only have 67,000 miles on it i have the sinister coolant filter and 6 gallons of cat ec-1 coolant oil changed every 4-5k with a egr delete.
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #9 of 9 Old 08-19-2013, 02:43 PM
onebadcoastie's Avatar
Quoted: 10 Post(s)
There's a lot of discussion on this topic. Going with the BPD cooler then leads to the discussion of what is more effective, air to liquid cooling or liquid to liquid cooling. Just some food for thought.
Shack
2016 F-350 CC Dually
2005 F250 CC FX4.SOLD
onebadcoastie is offline
