prices on air bags - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-14-2013, 07:49 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
prices on air bags
Guys I got a chance to pick up a used air bag set up. It has a LDC compressor, tank and the 2 firestone air bags for $200. It does work and bags are good. Only possible issue is that the set up came off a Chevy so I dont know how it will bolt up but Im sure Id have to buy the brackets.
So what do you think???
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 7 Old 08-14-2013, 07:58 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Also I was thinking more of using the compressor and tank for say a set of horn's and some light air tools (filling tires, maybe a tool if possible)
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 7 Old 08-14-2013, 02:29 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Wow...no thoughts?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 7 Old 08-14-2013, 08:36 PM
Chatham036's Avatar
Quoted: 134 Post(s)
Chances are, the compressor will not produce enough air to do much of anything with.
If you we're determined, you could mount a manifold and run a line to fill up bicycle tires and such
I just finished an on board air set up using a viair 450c
Thank goodness it is 100% duty cycle because that thing runs non stop to keep up with any air accessory or filling 37s.
It does kick butt at filling my air bags though
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #5 of 7 Old 08-18-2013, 09:58 AM
jetjock15's Avatar
Quoted: 111 Post(s)
Not the type of item you want to buy used and not specific for the truck, especially the frame brackets and bag rating. There not that expensive new. I have numerous friends I run with that have run bags for the last decade, they have all experienced one failure or another, my opinion of the Firestone type kits is very low.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #6 of 7 Old 08-18-2013, 02:10 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I think Im gonna take your guy's advice and walk away from these. I reeley wanted the tank and the compressor for horns and such but who knows how beat the pump is.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 7 Old 08-18-2013, 03:10 PM
Chatham036's Avatar
Quoted: 134 Post(s)
I purchased mine used and haven't had a single problem out of them.
