EOT and ECT question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-13-2013, 09:09 PM Thread Starter
dbrandone's Avatar
I just received my PHP FICM programmer in the mail and its awesome. The Programmer, which is also a Edge Evolution, will be my gauges that I have desperately needed(EGT Probe is on the way). I hooked everything up and FICM voltage and Trans temps look great but my eot and ect temps are that of concern. I am new to diesels and have spent the last year roaming around this site soaking up as much knowledge as possible. The eot and ect temps always stayed within 5-8 degrees so that's good and when I started driving the temps looked great in the high 180's but after driving it a bit they made it all the way up to 210. According to the monitoring sticky anything 200-215 should be "Heavy Service". Should I be concerned or is this common. I did romp on the engine a couple times but definitely not anything excessive.
Sent from AutoGuide.com App
2005 F-350 Lariat CC SRW LB FX4 - SIlver
Custom 6" Lift w/ Dual Bilsteins, 35/12.50/20 Nitto Trail Grapplers, 20x10 XD Strike Wheels in Matte Black, ARP Headstuds, PHP Gryphon FICM Programmer(Currently using Atlas 80), Volant Intake, 4" Turbo-back Straight Pipe Exhaust w/ 6in Tip, 6000k Retro Solutions 55w HID Kit
dbrandone is offline
post #2 of 9 Old 08-13-2013, 09:20 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
How warm was it? Mine hit 216 the other day on the hwy going to my buddies and it was over 100 degrees. Them I blew a o ring in the hpo system lol
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 9 Old 08-13-2013, 09:30 PM Thread Starter
dbrandone's Avatar
It was also about 100 degrees outside
post #4 of 9 Old 08-13-2013, 11:15 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
See what it's at on a normal day.
Oliver
ODAWG714 is offline
post #5 of 9 Old 08-14-2013, 01:39 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
What were your temps, both oil and coolant. Which one did you post? I'm assuming you posted coolant temp?
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 9 Old 08-14-2013, 01:56 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Up early huh Mitch?
MrOneEyedBoh is offline
post #7 of 9 Old 08-14-2013, 03:06 AM
If you were running it hard in 100 deg heat you could see temps like that, but like Mitch said, what was each temp? and did the temps come back down when you were not on it hard?
WLDHRSE is offline
post #8 of 9 Old 08-14-2013, 05:49 AM Thread Starter
dbrandone's Avatar
The 210 was oil temp and coolant was 204. When I would let up to normal driving the temps would drop maybe 3-4 degrees but once above 200 it never dropped back below. I will pay close attention to it today and see what it does.
post #9 of 9 Old 08-14-2013, 06:04 AM
PGreenSVT's Avatar
You're fine. Temps are typical for 100* plus weather. your delta is fine. No worries.
Yeah Anthony. Things to do, people to see. Actually woke up at 4 to pee and couldn't get back to sleep.
RIP Mitch
the Org crew
