Warren 175's or 190's - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-13-2013, 05:50 PM Thread Starter
lilgreen's Avatar
Truck started puking so its time to put it under the knife. Going with ARP studs regulated return kit FASS 125GPH titanium with 75psi spring, SnB intake elbow, Snow performance MPG max and coolant filter. Now I am on the fence for 175 or 190 injectors. I don't do a lot of towing. Maybe a 6k load from time to time. What would you go with?
2005 F-250 Crew Cab Short Bed King Ranch 4x4, 4" MBRP Turbo Back, SB Intake, 68mm Powermax, SCT X3, Boost, Pyro, Trans, Recon LED Clearance Lights, 35x12.50x18 Toyo Open Country MT'S
lilgreen is offline
post #2 of 15 Old 08-13-2013, 06:33 PM
Dirty_Stroke's Avatar
Dude you got a 68mm Pmax... Go 190's and don't look back!! I know you could tow 6k lbs no prob with that setup.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #3 of 15 Old 08-13-2013, 06:38 PM
JGman141's Avatar
go with the 190s
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #4 of 15 Old 08-13-2013, 06:54 PM
05f250harley's Avatar
i would go with 190s
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
post #5 of 15 Old 08-13-2013, 07:12 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I wouldn't run your fuel pressure at 75... That's way to high, a lot of guys actually make the most hp at 51-55 psi. I haven't looked into the Fass pumps in a while, but I know fass and adII doesn't have a good reputation with the 6.0. If you never tow heavy, I'd go with the 190's. What nozzle size are you getting?
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 15 Old 08-13-2013, 07:27 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
190/50 or 190/75
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #7 of 15 Old 08-13-2013, 07:29 PM
Quoted: 8 Post(s)
Does anybody know what hp difference there is between 50's and 75's... Estimate? I know that there is several contributing factors.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #8 of 15 Old 08-13-2013, 07:46 PM
JGman141's Avatar
Originally Posted by RollinEarly99 View Post
Does anybody know what hp difference there is between 50's and 70's... Estimate? I know that there is several contributing factors.
Not much of a gain going with 75s, 50s are big enough to empty the whole injector.
JGman141 is offline
post #9 of 15 Old 08-13-2013, 08:39 PM
snafu!'s Avatar
50s are uncommon when I got my injectors a couple months back warren didn't have any in stock.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #10 of 15 Old 08-14-2013, 03:02 AM
the chad's Avatar
Def go ahead and do 190s. I was on the fence with the same thing, went with 190s. You can always get em tuned back a little bit if you need to. Hell I wish I would have done 205's now.
Chad
07 F250
4'' MBRP to 7'' FTE Miter
ELC w/ Sinister Coolant filter
ARP's with OEM
Edge CS and Trans, Boost, FP on the pillar
Voltmeter in dash
Banjo's
Looney
Cal-Tracs
20x10 Monsters wrapped in 305 420s
RCD Egr Delete
Warren 190/75
Dozers RR
MTW Stage 2
557 hp/1206 ft/lbs
Big thanks to JJ @ Dozers And Adrian at MTW
the chad is offline
