Barder stage 2 review - Ford Powerstroke Diesel Forum
post #1 of 83 Old 08-12-2013, 03:09 PM Thread Starter
mechanix's Avatar
As many of you, I was in the boat of needing more air to clean up my tunes and injectors that I had installed AND still needed to tow loads of 7K+. I have been reading a lot about the Powermax turbos and the MTW turbos and was not really sold on one or the other. The reviews were kind of mixed and I was wanting something that was not going to perform out of the box and need a lot of tweaking constantly to get it to work. I came across Jame Barder and his turbo rebuilding skills. After a few chats with him I was sold on him rebuilding my turbo. I liked that he balanced the turbo and he had a short turn around time. So I took the plunge and sent him my turbo to be upgraded to the stage 2. Turn around was going to be 2-3 days which for me was nice after reading about the other turbo rebuilds taking a few months which in my eyes is no way to keep business or even get new business. I sent James my turbo to be fitted with a 64.7mm wheel and being I already had an 03 turbo the price would be cheaper cause he could machine my existing housing to fit the larger wheel. My first run I blew off the boot after the turbo, so I put it back on and tried again, it blew off again. I ordered some from Riff Raff boots and I will be putting them on very soon. OK enough of the back story on to the review.
I put the turbo on and instantly noticed a huge whooshing noise coming from under the hood that I never had before, this thing really sucks in some air! I noticed at 70mm my egts are about 100 degrees cooler, but where this thing really shines is at WOT. I am running 155/30 injectors from Warren. With the stock turbo with a BatMoWheel I could bury the egts, now with the Barder turbo I have seen a max of 1200-1300 degrees with my Extreme Street tune from Eric at IDP. Cruising around the street I see about 4-5 pounds of boost, before I was at 9-10 pounds. I bought this turbo to keep my EGT's down when I pull my camper, I have not pulled with it yet but I will next Friday. From a stop, mashing the pedal I get a puff of black smoke and then I'm off like a rocket with minimal smoke to a light haze on my Extreme Street tune. It seems that every time I drive it the manners are better than before and feels like it settling down into a groove. I think this will be a great towing turbo even on the Exteme race tune.
Eric
03 F350 Super Duty
ARP head studs
Warren 155/30% injectors
Barder Stage 2 turbo
SCT Tuner
EGR delete
35x12.50x20 Nitto Trail Grapplers
mechanix is offline
post #2 of 83 Old 08-12-2013, 03:30 PM
bondajb's Avatar
I am stoked... mine will ship tomorrow. . Glad it is working GREAT for you.
James seems like a great guy and you can not beat his turn around.
From another vendor I had to wait 4 months for a replacement turbo and when that one finally showed it was bad.. it took so long to get.... they forgot my address??? Really?
Good luck and keep us posted!!
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #3 of 83 Old 08-12-2013, 05:13 PM
Sure is a lot of success coming out of Barder's shop lately. Awesome to hear. Really looking forward to hearing how this turbo works out for you Aron.
Casey
05' F350 cclb born 12-9-04
4 inch down pipe, 5 inch exhaust no cat
atlas 40 ficm tune, SCT tunes, Dashboss
ARP studs, egr delete ,driven diesel regulated return, WPE up pipes
Warren 175/75? ( wish I knew the nozzle size! )
MTW stage II turbo ( this week )
Six inch lift and 35-12.50-18 AT-II's
slvr bullet is offline
post #4 of 83 Old 08-12-2013, 05:41 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
Nice this will be a good test keep us posted.
Bondajb do you have larger injectors? I know you were talking about them at one point but didn't see any in your sig. Just curious
Sent from AutoGuide.com App
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #5 of 83 Old 08-12-2013, 05:48 PM
bondajb's Avatar
How much weight will you be towing?
Are the tune you running for the stg2 or other?
I have to find a turbo that lives up to its claims before I add more fuel.. 175/30 casserly's are the plan
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
bondajb is offline
post #6 of 83 Old 08-12-2013, 06:22 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
Ya that's my plan or 175 stock. For the gain in HP I don't know if its worth it in the cost for nozzles. Derail over, back to the turbo talk lol
Future Mods:
-Alex
Fox Hunt is offline
post #7 of 83 Old 08-12-2013, 06:40 PM
1fastTRX's Avatar
Looks like im not the only one loving their BTS Stage 2. I wouldn't be scared to tow max weight with mine. I think the turbo will only shine more as the load increases.
2006 F-250 CCLB Lariat FX4
4" Rancho Lift with Wireless Ride adjustment (came with truck)
35" Toyo A/T Tires on 20" Eagle Alloys
4.10 gears
Ported intake manifold (Thanks odawg714)
ARP Head Studs
Bulletproof EGR Cooler
Tunes by Gearhead (SRLXX daily)
Dieselsite Coolant Filter Kit
ISSPRO gauges: Trans, EGT, Fuel Pressure
Airdog II 165
6.4l Banjo Bolts
PHP Original FICM tune
1fastTRX is offline
post #8 of 83 Old 08-12-2013, 07:23 PM
bondajb's Avatar
This whole game isn't worth the cost.. my hopes are with this turbo they will work well. They should be able to run the same as the OP's but with a bit more if wanted/needed
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
bondajb is offline
post #9 of 83 Old 08-12-2013, 07:36 PM
What is the specs on the stage 2? Is it just a bigger compressor wheel?
Moto2four is offline
post #10 of 83 Old 08-12-2013, 09:10 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
64.7mm single plane compressor wheel with a 10 blade turbine wheel
Future Mods:
-Alex
Fox Hunt is offline
