Anything else? - Ford Powerstroke Diesel Forum
post #1 of 30 Old 08-12-2013, 01:14 PM Thread Starter
Anything else?
Ok so I've been reading for the majority of the day on here about egr deletes and head studs and I'm about to go insane with all the information being thrown around.
I know what I want:
1. Sinister EGR Delete Kit
2. APR Head Studs
3. SCT tuner to offset the thrown codes
Now my question is do I NEED anything else before I tackle this project? I'm not really asking what I should ALSO get or should TRY and ADD but is there anything that is absolutely essential? I'm looking to do these things to my truck just to add power and mostly reliability and was hoping you guys could help steer me in the right direction. Like is it a must to do the oil cooler at the same time as the EGR?
Thanks for the help
06DieforDiesel is offline
post #2 of 30 Old 08-12-2013, 01:17 PM
Raul@Stealth Automotive's Avatar
ill add OEM gaskets... i would also do the cooler while your in their...
oh and we can get you a good deal on the setup if your interested
Raul@Stealth Automotive is offline
post #3 of 30 Old 08-12-2013, 01:18 PM
peixinho's Avatar
Quoted: 169 Post(s)
have you read this thread?
Write Up: Bullet-Proofing the 6.0L PSD.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #4 of 30 Old 08-13-2013, 11:44 AM Thread Starter
Holy crap that's a lot of information. And seems way more complicated and difficult (not to mention expensive) than I wanna dive into. IN my head I had the idea that I simply delete the EGR system, add ARP head studs and replace the oil cooler with the possibility of adding OEM gaskets, then throw on a simple flash programmer to turn off the error codes. I didn't think I'd need to add gauges and change oil and fluids to make all this work. Obviously I was expecting a much simpler fix.
post #5 of 30 Old 08-13-2013, 12:15 PM Thread Starter
what do you guys think about this? I've found a kit that pretty much includes everything I think I need and more. Its from XDP and its going for 1,159 plus an additional 5% off. (Sorry I cant copy the link)
The kit includes:
Full EGR delete kit
ARP Head studs
Black Onyx Head Gaskets
Ford Exhaust Gaskets
Ford Oil cooler with the oil cooler screen
Ford Intake gaskets
All the Turbo hardware
Does this sound about right and how about the price?
post #6 of 30 Old 08-13-2013, 12:23 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
hey man if you want to save a good chunk of money get the EGR delete from Custom Diesel... Made right here in USA!! I believe in Tennessee
MrOneEyedBoh is offline
post #7 of 30 Old 08-13-2013, 12:56 PM
mastrkee's Avatar
If you are going into your 6L and the STC, standpipes and dummy plugs haven't been upgraded then you will definitely want to do those while you are that close to them.
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #8 of 30 Old 08-13-2013, 01:00 PM
tylerb05's Avatar
Egr delete, coolant filter, sct tune with your choice of custom tune, exhaust? ALSO edge cts to read your temps. no need to do cooler unless your temps r super high or if you switch to a elc?
I still am waiting to switch to elc and oil cooler. but i will be doing it within this month but just a reg not a bpd remote oil cooler. tooooo expensssiiivvvveeee
i havent even re done my studs or anything yet. im not replacing them till its time. im at 192k miles
Tyler.
03 f250 king ranch 4x4 6.0, 2.5 level with bilistein 5100s,04 KR Rims with Toyo open country 33/12.5/18s , GONE LOONEY , bully dog cold air intake, mbrp 4inch turbo back exhaust 5inch tip, edge insight cts w/ egt probe, sinister coolant filter,Updated hcfm plug Blue Spring, Rotella T6,10k headlights and fogs, EGR Gone, ELC
Upcoming:
W/M injection
Injectors
tylerb05 is offline
post #9 of 30 Old 08-13-2013, 01:11 PM
peixinho's Avatar
Quoted: 169 Post(s)
Well now you know the whole story I did not do everything either but I watch my truck very carefully and I have plans to finish everything eventually.
KC Turbos
peixinho is offline
post #10 of 30 Old 08-13-2013, 01:13 PM
peixinho's Avatar
Quoted: 169 Post(s)
The kit includes:
Full EGR delete kit
ARP Head studs
Ford Intake gaskets
I would definitely not do black onyx... I would stick with Ford OEM. Ford OEM are more expensive but have much better success rate. Don't forget to budget for head work and possibly new heads. Most people don't think about that.
KC Turbos
peixinho is offline
