Trans tuning issues - Ford Powerstroke Diesel Forum
post #1 of 34 Old 08-12-2013, 09:42 AM Thread Starter
Quoted: 5 Post(s)
Feedback Score: 3 reviews
Trans tuning issues
Hey guys,
Any tuners out there that can tune a transmission so it shifts normal and good??? I have about had it with this truck, either it is a POS or tuners cant tune it.
I will just go ahead and rant - First tune I ever got was from vivian, it had a terrible shift flare from day 1 and I was told it was a problem with my 50K mile truck or user error, definitely not the tune. Well a few hundred miles later the trans was gone. I understood the risk I took by loading a performance tune just bummed it cost me a tranny on basically the first outting. However my hand was forced so I upgraded to PI stallion converter and billet input shaft along with new clutches and such.
I tried a tune from Chris at TSD and it was the best running tune but I couldnt get it to shift right at WOT. It wanted to push the shifts to 4300 no matter what we tried. He sent me a new tune and now it wont shift right unless I am under light throttle. Otherwise it wants to shift from 1-3 back to 2 then to 3 then to 5 - its like a bucking bronco.
I also tried Tony's tunes and the trans wanted to flare 3-5 and cruising boost was way too high, he fixed most of that but still has a slight flare and it was getting HORRIBLE fuel mileage compared to everyone else. The tune ran ok other than the tranny portion.
I dont want to just throw 100 dollar bills around to all the tuners to find out nothing works. I am pretty sure the tranny is fine because it runs like a top with the stock tune.
Should I maybe get away from the higher HP tunes? Anyone?
Thanks!
Todd
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #2 of 34 Old 08-12-2013, 09:57 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Call BTS, no one knows how better to tune for shifts better than Brian IMO.
CT Performance, Inc. is offline
post #3 of 34 Old 08-12-2013, 10:11 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
In my experience, Eric is the one tuner that when I asked for a very specific change to the transmission shifting, he was able to get it spot on. I like Chris's engine tuning better because the truck sounds and runs smoother but hands down, Eric could make what I wanted to happen actually happen with the tranny. I tried transmission tweaking with various other tuners and wasn't as lucky. Basically, they would send me back a "revised" tune and NOTHING had changed.
Like I said, just my experience here. Hope it helps.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 34 Old 08-12-2013, 10:15 AM
peixinho's Avatar
Quoted: 174 Post(s)
I am just throwing this out there but do you think maybe there is something else wrong besides the tune and/or the tranny.
I have a close friend/mechanic that had problems with his tranny. He though it was the tune, then he thought it was the tranny, he replaced his tranny and still had the problem and blamed it on the builder, then tried a different builder, then a stock tranny, he tried many different tunes... nothing fixed the problem.
He ended up having problems with a couple of bad sensors...
I had a similar problem with an old 7.3 that just would not shift right and it ended up being the ebp sensor
Good luck!
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #5 of 34 Old 08-12-2013, 12:24 PM
snafu!'s Avatar
I found that Matt's tunes from Gearhead are the best for the trans, I had Tony's extreme but I had a 3-5 shift flare then it stuck in 3rd with a brand new trans. I really liked the turbo tuning but not going to risk this new trans.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #6 of 34 Old 08-12-2013, 12:34 PM
HP MACHINE's Avatar
Quoted: 104 Post(s)
Don't give up , I've spent hundreds on tunes just to find out what works for me .
I use my truck as a daily driver and just wanted a really nice shifting
higher HP tune and I suggest you contact GEARHEAD and get matt's
srl + . Get away from all these race tunes , I couldn't any of
them to act rite .
They are useless in the real world of driving .
Matt's srl+ is the nicest driving and shifting tune period !
I'm not badmouthing any of these other tuners ( I think they do a
tremendous job of tuning truck's ) but be careful what you ask for
or you might get it.
PS . I have a library of tunes and his is the only one that gets used .
PHP also has nice ecm rollbacks that work really nice and when
combined with their ficm tunes , are even better .
Just my 2 cent's worth .
HP MACHINE is offline
post #7 of 34 Old 08-12-2013, 01:04 PM
I'm having similar issues like you are, I destroyed a PI converter, broke an input shaft and smoked the clutches due to what was thought to be tuning. Andy at warren diesel has been helping me tremendously to figure out this problem. We are now thinking that the transmission wiring harness maybe bad. He is sending me one and I should get it this week and I'm crossing my fingers that it works.
Amstaff is offline
post #8 of 34 Old 08-12-2013, 04:13 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'd agree that here is possibly something wrong with a sensor or solenoid in your trans. Try reloading your tunes and choosing default settings when loading the tune. I had trouble with my SRLxx shifting really badly and it turned out the shift pressure and shift points at wot where changed and once I reset it to defaults… all was well again!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #9 of 34 Old 08-12-2013, 05:17 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Hey bro,
How can you reset to defaults then load SRL? Mine feels a little funky at times.. Maybe I should reset to stock as you said.
MrOneEyedBoh is offline
post #10 of 34 Old 08-12-2013, 05:45 PM
Quoted: 8 Post(s)
When you are loading custom tunes... The device will ask you if you want to "load saved changes(setting)" or something like that. There is also a choose to reset to default, after you reset to default, make sure the only thing you change is the rpm rev limiter to 4500 rpms which is what Matt programs his tunes tune. I know some may not believe me so I'd ask him yourself... But you can save yourself the trouble (and his) because I've have emails proving that he said that if someone doesn't believe it.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
