What to do next? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-11-2013, 06:16 AM Thread Starter
paintballbryce's Avatar
What to do next?
Looking at getting some more stuff into my truck. Right now I have exhaust, xtreme x and wildman extreme tunes, blue spring mod, gauges, edge cts, studs, and just out on a set of 35s, with a newton leveling kit on the way. Looking at what will be my next best move to go for some performance gains? Also need something to help keep my axle hop down for when I sled pull. My fuel pressure is reading 54-56 at idle, and about 30 at wot with my blue spring mod, so if there is something I can do to help that? My egts are staying around 600-700 crusing, and around 1200-1350 at wot. Don't have all the money in the world, so I have to do the most cost efficent things first.
Any advice is much appreciated!
The things im considering:
Ficm tune from php
Turbo
Injectors
S&b intake.
2006 F250 Bulletproofed - SOLD
2008 F350 King Ranch
Stock for now
paintballbryce is offline
post #2 of 7 Old 08-11-2013, 06:23 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Water methanol??
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 7 Old 08-11-2013, 06:28 AM Thread Starter
I looked into that but it seemed like it didnt do as much as it stated for hp gains, and seemed expensive to lower egts when I dont have a problem. Is there something else to it that im missing?
Thanks!
Stock for now
post #4 of 7 Old 08-11-2013, 03:58 PM
peixinho's Avatar
Quoted: 207 Post(s)
I vote turbo and injectors... you will get your best bang for your buck out of those two. After that gains can be minimal
Edit: definitely get all you fuel pressure issues taken care of first and finish all you bulletproofing... I was just picking out of the list u had but then reread your fuel pressure issue
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #5 of 7 Old 08-11-2013, 07:05 PM
JGman141's Avatar
I would be looking into getting a new fuel system if its dropping down to 30, if you get bigger injectors and can't hold atleast 45 your going trash them.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #6 of 7 Old 08-11-2013, 07:09 PM Thread Starter
What kind of fuel system should I have? Airdog?
Thanks!
Stock for now
post #7 of 7 Old 08-11-2013, 07:15 PM
JGman141's Avatar
Stay away from the air dog 2, they are horriable. I would look into a a1000 with a air dog 150 lift pump and regulated return, that's what I'm looking at doing to mine soon
JGman141 is offline
