Anyone around sarasota? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-09-2013, 06:30 PM Thread Starter
Rollincoal941's Avatar
I want to do a blue spring mod and 6.4 banjo bolt for my 06 kingranch is anyone around sarasota area can help me out with this?
Rollincoal941 is offline
post #2 of 9 Old 08-10-2013, 07:03 AM
the chad's Avatar
There's plenty of write ups all over, it's a very simple install hour for both tops. A ratcheting wrench helps a ton on the banjos!
Chad
07 F250
4'' MBRP to 7'' FTE Miter
ELC w/ Sinister Coolant filter
ARP's with OEM
Edge CS and Trans, Boost, FP on the pillar
Voltmeter in dash
Banjo's
Looney
Cal-Tracs
20x10 Monsters wrapped in 305 420s
RCD Egr Delete
Warren 190/75
Dozers RR
MTW Stage 2
557 hp/1206 ft/lbs
Big thanks to JJ @ Dozers And Adrian at MTW
the chad is offline
post #3 of 9 Old 08-10-2013, 12:16 PM
im in clearwater
Ryan
2003 2wd 6.0 egr gone, blue spring, extremeX
305/50/20 nitto 420s (lowered in the rear)
205/100 bw66
Boost got you loose
13.4 with a 1.9 60ft spinning anit winning
YOUR CUMMINS MIGHT BE FAST BUT YOUR GIRLFRIEND LIKES MY SLOW POWERSTROKE
my youtube channel mostly 6.0 videos
risco is offline
post #4 of 9 Old 08-11-2013, 04:18 AM
5fifty's Avatar
Pretty easy to do..
LMK i'm in Venice... In Sarasota just about every day.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #5 of 9 Old 08-11-2013, 04:35 AM Thread Starter
I live in Venice also just go to sarasota for work and such everyday
post #6 of 9 Old 08-12-2013, 05:31 PM
5fifty's Avatar
Let me know if you need a hand
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #7 of 9 Old 08-12-2013, 05:56 PM
elchaseo's Avatar
Quoted: 8 Post(s)
I'm in port charlotte but work on longboat key. Good to see there are people close by.
2015 F250 Lariat- CAI, CCV Reroute....more to come
elchaseo is offline
post #8 of 9 Old 08-12-2013, 07:43 PM Thread Starter
5fifty yes I would love some help I seen in your sig that you have done this already I'm going to ford tomorrow to pick up the kit maybe when you are free we can get this done do you have all the tools to knock this out?
06 f250 kingranch FX4
Arp head studs oem gasket Airraid intake
egr delete byebye 5inch mbrp turbo back 8inch mbrp tip Sinister coolant filter elc coolant updated stc fitting stand pipes dummy plugs new oem injectors 6.4 banjo bolts blue spring Sct livewire ts with Vivian looney wild tony wildman extreme Super panty dropper
8inch procomp lift 4inch with airbags in the rear
Custom headlight painted kr red hids and leds everywhere! 692 moto metal with 37s mud grapplers
post #9 of 9 Old 08-15-2013, 06:19 AM
5fifty's Avatar
LMK... I usually have all my tools with me. Weekends r best for me. Sometimes I have a free day during the week.
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
