SCT HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-09-2013, 05:54 PM Thread Starter
juniorssrollin's Avatar
Quoted: 2 Post(s)
SCT HELP!!!
Hey everyone, I bought a used SCT X3 (3000), it is unlocked and has 5 unlocks left.
Put Vivian's tunes on the unit and go to upload them to my truck. 3 error codes.
I have an older edge with a little black box under the hood that is plugged into the ECM with large wire bundles. I turned this all back to 0 or off. I still want that as a monitor for the time being.
Do I need to unplug the edge setup to upload my new tunes?
called SCT and they said it could be a voltage problem so hooked the drivers side battery to the charger and no changes.
HELP!!!
Sent from AutoGuide.com App
ID:	152338   Click image for larger version
ID:	152346   Click image for larger version
ID:	152354   Click image for larger version
2005 F350 CCLB FX4
juniorssrollin is offline
post #2 of 15 Old 08-09-2013, 06:36 PM Thread Starter
Quoted: 2 Post(s)
Bump! I'm towing tomorrow so would like to get this squared away
2005 F350 CCLB FX4
post #3 of 15 Old 08-09-2013, 06:43 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
This is the only code (1017) I could find on SCT website. The other two aren't listed.
http://www.sctflash.com/support/inde...eid=18&nav=0,1
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 15 Old 08-09-2013, 06:57 PM Thread Starter
Quoted: 2 Post(s)
I did the find updates automatically on the SCT uploaded program, before loading my tunes onto it.
I have a hunch it has something to do with that Edge.
2005 F350 CCLB FX4
post #5 of 15 Old 08-09-2013, 07:36 PM
Adamv7010's Avatar
I'm fairly certain you'll need to do away w the edge stuff and reload the stock file. Then load the sct.
Adamv7010 is offline
post #6 of 15 Old 08-09-2013, 08:29 PM Thread Starter
Quoted: 2 Post(s)
So I can't even use it as a monitor?
2005 F350 CCLB FX4
post #7 of 15 Old 08-09-2013, 08:41 PM
jmeaby's Avatar
Quoted: 16 Post(s)
I think since it is plugged into the ecm it needs taken off I could be wrong
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #8 of 15 Old 08-09-2013, 10:21 PM
john galt's Avatar
Quoted: 1231 Post(s)
i really do not know but i seem to remember reading here somewhere that you have to disconnect the edge return to staock, then load your tunes then reconnect the edge to use as a monitor. not at all certain of this but i think i read that somewhere. i am just buying my looney tune and have not even finished the order or loaded it yet so take this with a grain of salt.
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is online now
post #9 of 15 Old 08-09-2013, 10:36 PM
Adamv7010's Avatar
As a monitor yes...but in your original post you said you loaded the tunes to the unit...THEN TRIED TO LOAD THEM TO YOUR TRUCK....doing so with the edge intact is called stacking tuners. And no. You can't do that. Ditch the edge completely...sell it...load the sct...done deal.
And start saving for a transmission.
post #10 of 15 Old 08-09-2013, 11:45 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
Completely return the truck to stock and diconnect edge... start the truck and make sure everything is Kosher.... then load the SCT.. once tuned you can plug the edge back in and run it as a monitor only.... at least thats what ive always read....
does teh edge plug in via obd2 or actually hardwire into the ecm?.. if its not obd2 then you can not run it at all
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
