3.5" vs 4" down pipe - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-09-2013, 05:36 PM Thread Starter
AaronB.F250's Avatar
Quoted: 2 Post(s)
Hey guys have a question here that hopefully I can get some input on. I bought an exhaust with a 4" downpipe for my 6.0 and thought I made a good choice. Long story short my brother in law (ford diesel tech) told me anything over 3.5" was a waste and I would loose torque from a 4"down pipe. Now I'm hesitant to put it on. Truck is also stock exhaust is first mod I'm doing. Any help or thought would be appreciated.
Aaron
AaronB.F250 is offline
post #2 of 10 Old 08-09-2013, 05:49 PM
not sure if I felt anything- But all I know is, when you open the hood I have a real mans downpipe looking at you
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #3 of 10 Old 08-09-2013, 05:55 PM
I personally have a 4" DP with out any issues. This has also been talked about a lot with a lot of varying opinions. In talking with a tuner, basically he told me yes you loose a little torque ( throttle response) taking the cat off, then moving to a 3.5" from 3"then to a 4 from 3.5" with each change but you gain HP on the top end and lower EGT's. So it's a trade off it seems and which works best for your build. However I don't think it's ever been shown on a dyno at least not that I know of and may not even show up then. More than likely the old Butt-O-Meter might be the only way since it off idle and on the very low RPM side of things that it would show up. But others can chime in and give there thoughts.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #4 of 10 Old 08-09-2013, 06:01 PM
When my truck was all stock the first thing I did was a full exhaust with 4"dp... I def. lost low end torque... Now with my mods im sure the 4"er helps now.
bpd
Warren comp trans
04cr450 is offline
post #5 of 10 Old 08-09-2013, 06:08 PM Thread Starter
Quoted: 2 Post(s)
Thanks for the input guys I really do appreciate it all. I am going to go ahead and throw the 4" on I think. Is. A diamond eye 5" exhaust with 4" downpipe. Next mod on the list is an h&s minimaxx so I'm thinking down the road the 4" will help, also like the thought of the lower gets. Thanks again all. Keep me coming if you want.
Aaron
post #6 of 10 Old 08-10-2013, 06:42 AM
The larger exhaust to help with egts. When you start cranking up the fuel the egts go up.
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #7 of 10 Old 08-10-2013, 08:50 AM
I saw you mentioned a mini max. Why would you buy that tuner when it has been proven over and over that the tuner to buy for a 6.0 is an SCT. On the fly tuning is not a good idea with these trucks. You will be far happier with an SCT and some custom tunes and your tranny will thank you in the long run.
F350$PIT is offline
post #8 of 10 Old 08-10-2013, 10:10 AM
colonel angus's Avatar
Quoted: 2 Post(s)
Mini Max is a Mini NoNo, take the advise of 9 out of 10 Dentists.... go with an SCT and live happy ever after...
d
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #9 of 10 Old 08-10-2013, 12:52 PM Thread Starter
Quoted: 2 Post(s)
Thanks a bunch for the input on the tuner guys. Again maybe my biggest problem is that I listen to my brother inlaw (ford diesel tech)a little to much and take his word on everything. I honestly never thought of the SCT but I have seen a lot of guys on here running them. Guess I need to bury my nose in the forum a little more and go with 9 out of 10 dentist approach. Lol thanks for input guys. Keep it coming. The more I'm reading the 4" downpipe appears to be a good move if I'm gonna be putting more fuel to it
post #10 of 10 Old 08-11-2013, 08:57 AM
shawnb99's Avatar
j really doubt that you lost ANY performance with the 4" DP. do you gain anything....maybe not other than lower egt's.
what you think you lost was the feel of having more torgue, but I would bet money , that it was actually a gain, across the board.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
