BPD oil bypass filter question- - Ford Powerstroke Diesel Forum
post #1 of 22 Old 08-06-2013, 04:56 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Just got done with the install and Im enjoying the happy thoughts about all that scrubbed clean oil running around. My question pertains to the line that connects to the oil fill cap. I was wondering if anybody has come up with maybe a quick connect type of a connection?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 22 Old 08-07-2013, 06:03 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Bump for the day
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 22 Old 08-07-2013, 11:30 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Mine has a swivel on it so that I can remove my cap without disconnecting the line... Talk to the guys at BPD. Kinda surprised they didn't suggest it when you were ordering your bypass kit.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 22 Old 08-07-2013, 12:27 PM
portcity_gt's Avatar
Quoted: 1393 Post(s)
Yep mine also has a 90° swivel fitting. I got from bpd.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #5 of 22 Old 08-07-2013, 01:48 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Well dang guess Ill give em a call. Right after I check the box and make sure I didnt forget to put it on.....
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 22 Old 08-07-2013, 02:23 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Once again I prove that I truly am a moron. The Swivel was on the end of the line. It is just stiff from being new.......you can all go home now.......nothing more to see here.........moron got out of his cage..........
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 22 Old 08-07-2013, 05:13 PM
kcoyner's Avatar
Quoted: 74 Post(s)
Good to know that you can laugh at yourself! And glad I'm not the only one who does dumb s#!+!
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
post #8 of 22 Old 08-07-2013, 05:29 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
it happens man! Has anybody seen their oil as clear as honey after installing the bypass filtration system? How many miles (or time) did it take to clean the oil? What brand of filter was it? Sorry for the hijack, but this thread is dead now anyway! Hahahahaha
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #9 of 22 Old 08-07-2013, 06:02 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I don't know if Ill get that "clear as honey" oil. I have the upgraded EGR not the delete. And Ive been told that the EGR is mostly what I causing the black in the oil. May not be true, don't know.I do know its gotta be cleaner that what I just changed out!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 22 Old 08-07-2013, 06:12 PM
Quoted: 8 Post(s)
Your running the EaBP100 filter... Or the EaBP110?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
