Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
  #31 (permalink)
Old 06-02-2008, 08:53 PM
darsey715 darsey715 is offline
Send a message via AIM to darsey715
Originally Posted by zachs04250 View Post
the only plates i found at discount was for the gmc/chevy, and that was a streatch to find, i dont realy want to use a plug i want to b able to take it out easily just in case.
either way, taking a plug out or swapping out up pipes...it's not really gonna be easy.
  #32 (permalink)
Old 06-03-2008, 06:35 AM
Santa Gertrudis Santa Gertrudis is offline
Originally Posted by Evil Eye View Post
DJ turns the EGR valve off in his tuning, so the exhaust gasses never get back into the intake, so all you would need is to block off the flow into the EGR cooler. That's where the block off plate or freeze plug come in to play. Some folks choose to remove the EGR cooler all together, which will prevent any failures with coolant flow from the oil cooler and through the EGR cooler. Sometimes they will clog up with casting sand from the block, which is why I have a bypass coolant filter kit on mine. Let us know if you still have questions.
Yea, I thought it was turned off in the tuning. Is there a link somewhere about removing the cooler all together?
  #33 (permalink)
Old 06-03-2008, 07:53 AM
BLACK_PSTROKE BLACK_PSTROKE is offline
liberatorperformance.net offers a kit that will remove everything. but its a little more $$ than the other ways that have been mentioned
  #34 (permalink)
Old 06-03-2008, 11:05 AM
http://www.powerstroke.org/forum/6-0...-new-post.html
Liberator is robbing people. $600 for an up pipe and a rubber hose. can't believe people buy that crap.
  #35 (permalink)
Old 06-03-2008, 11:15 AM
Abrannan19 Abrannan19 is offline
here is another
GoGoDiesel Forums
  #36 (permalink)
Old 06-03-2008, 02:06 PM
william_04_x william_04_x is offline
Originally Posted by darsey715 View Post
He's not getting 5-6 more miles to the gallon. I guess you could do that but I consider that to be kinda janky.
may seem janky, but the "zip tie mod" was one of the first solutions to EGR problems..the functional valve would sit outside the motor and operate as normal to keep EGR position codes from popping up...that truck is a piece of 6.0 history...
  #37 (permalink)
Old 06-03-2008, 08:34 PM
wow, i had no idea it cost that much.... OUCH!!!!!!
  #38 (permalink)
Old 06-03-2008, 08:38 PM
zachs04250 zachs04250 is offline
Send a message via AIM to zachs04250
thanks for the link
  #39 (permalink)
Old 06-03-2008, 08:41 PM
Originally Posted by DryHeatDude03 View Post
Here ya go Zachs Discount Power Parts
thanks for the link
  #40 (permalink)
Old 06-06-2008, 06:50 PM
egall2000 egall2000 is offline
Hey guys after reading it up finally took the plunge and did a complete EGR removal. My egr cooler went out white smoke blah blah, so instead of putting the $591 factory cooler back in I just did it my self. Well kinda, my folks flew down for the week to see the grandkids and I stole my dad for extra hands.
Followed the write up of the complete removal ( Mudracer, evil eye)
Really great!!! on the money with just about every thing. I cut both ends of the cooler of and reused the V-band clamp on the uppipe and bolted the other end to the intake manifold. Also wielded the egr valve closed. no CEL but if i check the dtc's with the cortex it is showing that the egr valve is not working right. he he
Any way So far so good really happy with the results and truck seems to be alot happier as well
Total Price:
Rubber hose $6.50
Freeze plugs 2 $1.00
New Fuel filter cap $70.40
Letting somebody else wield $60
Over all MUCH Cheaper than any pre made items
GOOD LUCK WITH YOURS
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
