Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
  #21 (permalink)
Old 05-29-2008, 09:15 PM
FOMOsuperduty FOMOsuperduty is offline
Guy I work with had a extra egr valve and plugged that one in and left the old one in the engine unplugged. He zip tied the plugged in one to the engine and has been getting 5-6 more miles to gallon. Will this work in the long run or is there future problems??
  #22 (permalink)
Old 05-29-2008, 09:32 PM
03f250stroke 03f250stroke is offline
Location: Toms River, NJ (yeah its better then South Jersey)
seriously? i would hit the guy in the face with a hammer next time i see him
  #23 (permalink)
Old 05-29-2008, 09:39 PM
darsey715 darsey715 is offline
Send a message via AIM to darsey715
He's not getting 5-6 more miles to the gallon. I guess you could do that but I consider that to be kinda janky.
  #24 (permalink)
Old 05-31-2008, 09:58 PM
zachs04250 zachs04250 is offline
Send a message via AIM to zachs04250
is there a plate that can be found to put in between the uppipe and egr or will i have to fab one up
  #25 (permalink)
Old 05-31-2008, 11:56 PM
DryHeatDude03 DryHeatDude03 is offline
You can buy one, I believe Discount Power Parts has them. Or you can fab one up, or can install a steel freeze plug.
  #26 (permalink)
Old 06-01-2008, 05:04 AM
Santa Gertrudis Santa Gertrudis is offline
So if you get a block off plate (up pipe), what else is really needed to do away with the EGR problems? EGR systems are where I get confused on these trucks.
  #27 (permalink)
Old 06-01-2008, 05:05 AM
Evil Eye Evil Eye is online now
Slacker
The block off plate is just a stamped piece of metal; you might just get a steel freeze plug for a few dollars.
  #28 (permalink)
Old 06-01-2008, 05:11 AM
Slacker
DJ turns the EGR valve off in his tuning, so the exhaust gasses never get back into the intake, so all you would need is to block off the flow into the EGR cooler. That's where the block off plate or freeze plug come in to play. Some folks choose to remove the EGR cooler all together, which will prevent any failures with coolant flow from the oil cooler and through the EGR cooler. Sometimes they will clog up with casting sand from the block, which is why I have a bypass coolant filter kit on mine. Let us know if you still have questions.
  #29 (permalink)
Old 06-02-2008, 08:40 PM
the only plates i found at discount was for the gmc/chevy, and that was a streatch to find, i dont realy want to use a plug i want to b able to take it out easily just in case.
  #30 (permalink)
Old 06-02-2008, 08:43 PM
Here ya go Zachs Discount Power Parts
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
