Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
  #11 (permalink)
Old 05-10-2008, 08:49 PM
darsey715 darsey715 is offline
Send a message via AIM to darsey715
Originally Posted by zacdiesel01 View Post
ok call me a dumb newbie but why would you need to weld the EGR valve closed if you block the exaust flow?
you don't need to, blocking the exhaust flow is the main thing.
  #12 (permalink)
Old 05-11-2008, 04:51 AM
Evil Eye Evil Eye is offline
Slacker
David's right. You don't need to, but closing your EGR valve will prevent the hot gasses from accumulating in your up-pipe since the flex area can also rupture. My EGR valve is programmed shut in my custom tunes...
  #13 (permalink)
Old 05-12-2008, 06:41 PM
zacdiesel01 zacdiesel01 is offline
o ok cool so if i block the exaust flow and unplug the valve i should be good?
  #14 (permalink)
Old 05-12-2008, 06:43 PM
Slacker
Yep. You can also program your EGR closed in your SCT tunes. That's how mine is done.
  #15 (permalink)
Old 05-12-2008, 06:56 PM
thats cool. i have an EDGE now. i am gonna swich to the sct as soon as i get some money. what would you recomend?
  #16 (permalink)
Old 05-12-2008, 07:02 PM
Slacker
If you already have gauges, I would go with the Xcal2 or Xcal3 from either DJ's Diesel Performance or Eric@ Innovative Diesel.
  #17 (permalink)
Old 05-16-2008, 06:40 PM
i was looking at the live wire because i have the additude. and i use that as my guages.
  #18 (permalink)
Old 05-16-2008, 07:29 PM
Slacker
You won't need the livewire, since that includes the gauges. Go with the Xcal3; same thing, but no digital gauges.
  #19 (permalink)
Old 05-21-2008, 02:35 AM
commosmart1 commosmart1 is offline
If you install the blockoff plate, what is welding the freeze plug in for? Where does it go? Also, what does blockin the egr cooler solve, or improve? Thanks!
  #20 (permalink)
Old 05-21-2008, 05:16 AM
Slacker
If you install the block off plate, there is no need for the freeze plug. It goes in the y-section of your up-pipe feeding into your EGR cooler. It prevents your EGR cooler from rupturing, which is a fairly common problem.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
